Old 05-27-2010, 11:39 PM   #1
using mountig secrew for grounding
at couple locations, the original installer looped the ground wire around the mounting screw of the switch in stead of using the "ground screw." i have found this for both plastic as well as metal boxes.
while the contact seems to be good so the grounding is being achieved, i thought this a code violation. is it?
drgkjd is offline   Reply With Quote
Old 05-28-2010, 01:02 AM   #2
nap
You talking to me?
nap's Avatar
yes it is. a ground screw is required for a ground connection
basically, if the device comes loose, the wire may not be held against the metal and you could lose your ground connection.
Now, there is such a thing as a "self grounding device" where the mounting screws into a metal box are acceptable as the EGC to the device but a wire wrapped around the screw is never acceptable.
The Following User Says Thank You to nap For This Useful Post:
drgkjd (05-28-2010)
