Using Hair Straightner With Transformer... - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2007, 07:15 PM   #1
COF
Using hair straightner with transformer...
I brought some GHDs in the US without thinking, (should have brought in the UK, even just the straightener is much cheaper). Anyway, I have a transformer that converts 110v to 220 and 100 watt, that I've used for a games console, but some have told me using a hair straightner with a transformer is still not a good idea. Will it not work as well? Or does it still run the risk of burning out even with a converter? The straightener is 20-25 watts, whether that is at it's normal running condition, or whether that's its maximum I don't know.
COF is offline   Reply With Quote
Old 09-10-2007, 07:59 PM   #2
Once fried, twice shy.
elkangorito's Avatar
What is the supply frequency of where you intend to use it? 50 Hz or 60 Hz? What is the rated operating frequency of the hair straightener?
Switchboard design engineer & Licensed Electrician (Australia).
elkangorito is offline   Reply With Quote
Old 09-10-2007, 08:20 PM   #3
COF
The frequency of the supply I assume would be the standard 50Hz used in Europe, it's just a standard UK powerpoint. In looking through the manuel, it doesn't say anything about it opporating at 50Hz, so I can only assuming it's designed to opporate at 60Hz. Does the cycles make a huge amount of difference?
Old 09-10-2007, 08:35 PM   #4
Assuming that;
a] the device is designed for 60 Hz,
b] you will be using it on a 50 Hz supply,
c] the device is inductive (uses a coil of wire as the heating element),
it may run a little warmer than normal, which may cause some damage to it over time.
door bell transformer install? THEBIGPUNN Electrical 2 09-09-2010 07:01 AM
Can I use lv transformer for coolbox? gord115 Electrical 4 06-23-2007 10:09 AM
Hair in tub drain danceken Plumbing 5 05-24-2007 08:53 PM
dead transformer otis_ofnh Electrical 3 02-11-2007 12:19 AM
