-   -   Using hair straightner with transformer... (http://www.diychatroom.com/f18/using-hair-straightner-transformer-11436/)
COF 09-10-2007 07:15 PM
I brought some GHDs in the US without thinking, (should have brought in the UK, even just the straightener is much cheaper). Anyway, I have a transformer that converts 110v to 220 and 100 watt, that I've used for a games console, but some have told me using a hair straightner with a transformer is still not a good idea. Will it not work as well? Or does it still run the risk of burning out even with a converter? The straightener is 20-25 watts, whether that is at it's normal running condition, or whether that's its maximum I don't know.
elkangorito 09-10-2007 07:59 PM
What is the supply frequency of where you intend to use it? 50 Hz or 60 Hz? What is the rated operating frequency of the hair straightener?
COF 09-10-2007 08:20 PM
The frequency of the supply I assume would be the standard 50Hz used in Europe, it's just a standard UK powerpoint. In looking through the manuel, it doesn't say anything about it opporating at 50Hz, so I can only assuming it's designed to opporate at 60Hz. Does the cycles make a huge amount of difference?
elkangorito 09-10-2007 08:35 PM
Assuming that;
a] the device is designed for 60 Hz,
b] you will be using it on a 50 Hz supply,
c] the device is inductive (uses a coil of wire as the heating element),
it may run a little warmer than normal, which may cause some damage to it over time.
