Using Ground Wire For Neutral And Ground. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 12:50 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by Yoyizit View Post
Thanks for your help.
I have no doubt that this situation has happened, but. . .just so I'm clear on this
-what color wires is the tech measuring between?
The grounding conductors.
-what color wires go to the computer plug H, N and G?
There is no grounded (neutral) conductor in the box, this is the point of the graphic to begin with, it was just a switch loop and someone added a receptacle. You will find this code violation done most often when a 'well pump' installer adds a water softener and there is only 240v supply to the well pump.
I expanded the image on my screen but it's still blurry.
In any case I'm having trouble getting the 80v.
I could imagine 60v due to the RFI filter inside the computer but I won't know until I hash out these colors.
you are one odd duck.
Also, what has changed that this is no longer allowed?
This was NEVER, EVER, allowed!!! You can immediately see the safety issues with this setup.
The Following 4 Users Say Thank You to stickboy1375 For This Useful Post:
frenchelectrican (07-30-2012), Jim Port (07-29-2012), Missouri Bound (07-29-2012), Speedy Petey (07-29-2012)
Old 07-29-2012, 03:03 PM   #17
Missouri Bound's Avatar
Do you want it your way or the right way?
Old 07-29-2012, 03:39 PM   #18
I've worked in a LOT of older apartments and condos built in the 60's and up that have romex feeders with neutral and grounding conductors that terminate to the same bar in the subpanels.
It's always the same, the neutral and ground are bonded in 3 places, in the main disconnect, in each individual unit's disconnect, and in the panel up inside the apartment. When replacing these subpanels I've always separated them, but I've never actually had an issue of stray voltages in these buildings, oddly enough.
Phildaglass is offline   Reply With Quote
Old 07-29-2012, 03:41 PM   #19
E2 Electrician
You wont necessarily have a stray voltage problem until you lose a neutral connection along the way. The problem is parallel paths though, and getting in between those currents when they should not exist to begin with.
uh-oh, no ground wire darkhorseacers Electrical 6 01-08-2012 10:57 PM
can #6/2 NM wire (White,Black, bare wire ground be used for spa ? T-texas-43 Electrical 2 06-04-2011 08:23 PM
Adding a ground wire to a fixture? dkeith Electrical 2 06-01-2011 08:08 PM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
