Using Ground Wire For 3 Way Switch? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-08-2008, 10:25 AM   #16
joed's Avatar
Rewards Points: 12,024
The kid is dead and that is very sad. However there is lot of untold stuff and misinformation as to why. There was other problems besdies the ground as current carrying conductor, with this installaton and probably some fault with the door opener.
Old 04-08-2008, 06:35 PM   #17
So how exactly does a garage door become hot?
One possible scenario.
The "electrician" forgets a switch leg for the garage lights (or forgot the GDO outlet)
He finds the feed for the garage door opener originating in the house, uses the neutral for his sw leg and the ground for his neutral.
He installs the ground/neutral wire to the ground terminal on the outlet.
Somehow (bad connection/loose wire??) he loses the neutral somewhere between the box he monkeyed with and the source.
The currrent from the GDO/lights is being carried to "ground" via the ground pin on the GDO, thru the metal harware, thru the door to the wet driveway.
Possibly but not necessarily.
220/221 is offline   Reply With Quote
Old 04-08-2008, 09:52 PM   #18
I had a call about a garage door being installed and zapped the installer with 120v.
Found the original underground feed was rotten (old cast iron plumbing pipe used as grounding conductor). Ungrounded conductor was cut and heating up the garage side of pipe.
Door opener guy will check for power on his tracks from now on.
From what I remember he got hit twice..he didn't believe it was possible the first time.
NAIL is offline   Reply With Quote
Old 04-09-2008, 12:35 PM   #19
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
A short circuit, putting 120 volts on the door, with no low impedance path back to the source to open the circuit breaker. The door would be mounted to wood framing, and would have a rubber gasket at the bottom. That would insulated the door until a wet little boy contacted the door and the cement driveway. The missing equipment grounding conductor is the cause. That electrician is very lucky I am not that little boy's grandfather.
jrclen is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 09:23 AM
Two ground wires for one switch, none for another? josquin Electrical 5 07-01-2007 03:31 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
