#1 |
Using ground wire for 3 way switch?
Is this a big no no?
#2 |
If you connect it to anything other than the green ground screw, YES it is a big problem. The ground wire is not supposed to carry current. Plus then what do you use for ground wire? Replace the cable with the proper one.
#3 |
Licensed Electrical Cont.
Sure, you can use a ground wire to ground a 3-way switch. Makes no difference if it is a 3-way or single pole.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#4 |
A little late for an April Fools joke, isn't it?
#5 |
Licensed electrician
Are you asking about using the ground for a current carrying part of the switch wiring?
#6 |
Electrician
Using ground wire for 3 way switch? |
#7 |
Res Ipsa Loquitur
It is called a ground wire and is to be used for that alone...
Did you ever stop to think, then forget to start again? |
#8 |
If this guy did not have so many posts I'd swear it was a joke or troll post.
I am really afraid it's not.
#9 |
LOL, I'm trying to put a 2 way switch and need 3 current carrying wires. I guess it's time to try to fish a new wire.
#10 |
When is fishing season?
Well, at least he came here to ask and chose not to do it...
I DON'T OWN MY HOUSE... MY HOUSE OWNS ME!
#11 |
#12 |
A lot of news hype inthat story, like the claiming the wire overheated. Overheating had nothing to do with this problem.
#13 |
So how exactly does a garage door become hot?
#14 |
It's a good thing the work was done by a qualified electrician. A hack like me that pulls permits, and has everything inspected might not do as good a job.
#15 |
Hype? A kid is dead because some electrician took a shortcut. Maybe the newscasters used the wrong terminology, but it doesn't change the facts of the story.
| Display Modes | |
| Wiring double switch for new ceiling fan | toolmanwannabe | Electrical | 17 | 11-15-2011 10:34 PM |
| This doesnt seem right. | JoulesWinfield | Electrical | 27 | 07-26-2009 08:40 PM |
| Can you wire a 3-way circuit with 2 wire + ground | mnyman2003 | Electrical | 8 | 12-04-2007 09:23 AM |
| Two ground wires for one switch, none for another? | josquin | Electrical | 5 | 07-01-2007 03:31 PM |
| Subpanel feeder questions | Silhanek | Electrical | 4 | 03-22-2007 07:30 PM |
