Using Ground Crimp Rings - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2008, 07:06 AM   #1
When is fishing season?
CowboyAndy's Avatar
Using ground crimp rings
What is the proper procedure for using them? I have used them a few times, but am unsure if I am doing it right.
How many times should I twist the wires?
Can I use standard linemans pliers to crimp them?
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 02-26-2008, 08:42 AM   #2
Licensed electrician
Rewards Points: 1,296
Look on the package to see which tools are acceptable to crimp with.
Standard linesmans probably do not generate the correct crimping forces.
Old 02-26-2008, 08:47 AM   #3
CowboyAndy's Avatar
So what kind of tools are there out there to crimp with?
MY HOUSE OWNS ME!
Old 02-26-2008, 09:38 AM   #4
Here is one tool.
http://www.idealindustries.com/prodDetail.do?prodId=C24
Old 02-26-2008, 11:33 AM   #5
Rewards Points: 150
Just use a tool that has a non-insulated crimper section. Klien makes one just for that purpose or their yellow handled lineman's has it built in below the head.
kgphoto is offline   Reply With Quote
Old 02-26-2008, 01:34 PM   #6
Is this one of the tools listed for use with the crimp? Probably not.
Old 02-26-2008, 02:18 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
Wanna bet?
A standard lineman's pliers, WITH the crimper under the joint, IS an approved tool to crimp ground barrels.
Old 02-26-2008, 02:20 PM   #8
Ideal #30-420
Old 02-26-2008, 05:22 PM   #9
Electrician
Originally Posted by Speedy Petey View Post
Ideal #30-420
nice find...
chris75 is offline   Reply With Quote
Old 02-26-2008, 05:35 PM   #10
That's why I use Ideal side cutters instad of the industry standard Klien's.
Makes more sense than carrying an extra tool.
220/221 is offline   Reply With Quote
Old 02-26-2008, 06:36 PM   #11
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
why would that be? Klein offers linesman pliers with the same style as those Ideals.
Old 02-26-2008, 09:07 PM   #12
I've used Channellock's 909 cutter/crimper for years now. Good quality. Plenty powerful to crimp those ground wire sleeves.
Here's a link:
http://www.denlorstools.com/home/dt1...ol_cha909.html
End Grain is offline   Reply With Quote
Old 02-26-2008, 09:32 PM   #13
Yes, those are also on the list. Klein, T&B, Ideal, and others make exact versions.
Old 02-26-2008, 10:06 PM   #14
electrical contractor
Rewards Points: 150
I bought 2 pairs of Buchanan c-24s at a flea market for $9.00 each, so Ijust use those.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 02-26-2008, 10:41 PM   #15
Rewards Points: 2,350
Hey, you guys know what else works great for crimping grounds? A wirenut.
InPhase277
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
New Zurn Pex Crimp Tool and Rings berninarita Plumbing 1 01-27-2008 06:24 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 02:23 AM
Ground rod blues!!! ra_doliv Electrical 8 09-03-2007 12:48 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
