Using Gfci Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 11:56 AM   #1
using gfci breakers
my late '50s house was purchased and "refurbed" after hurricane Katrina by a contractor intent on "flipping" it. long story short, he cut every corner possible and invented some new ones along the way.
the house had 2 conductor wiring and altho the house got 4' of water in it and the sheetrock had to be replaced, he did *not* rewire. he ran 12ga green wire from to/from every outlet/switch/fixture using press-on connectors rather than wire nuts. so what we have now is a "grid" of ground wires in the attic and in the walls which end at the main subpanel ... a total of 8 sets.
this seems to me to be a particularly poor way to add grounding to old 2-conductor wiring. i was wondering if i should rip the green wires out and replace the breakers with gfci breakers. any advice? thanks
peyton
peyton is offline   Reply With Quote
Old 10-27-2010, 12:08 PM   #2
Rewards Points: 78
It's perfectly compliant to run a separate ground wire according to the NEC. However, the wires must be protected from physical damage and terminate at the panel board for each circuit just like a neutral must do. My biggest concern is how it passed inspection?
I know of no jurisdictions where when the walls are open the contractor/builder/HO would not be required to pull new cables. Renovations at this level would definitely require new wiring. If the house was not permitted and inspected, then too bad and shame on whomever owns it..
Old 10-27-2010, 12:15 PM   #3
GFCI breakers will not give you a ground connection in any way
Old 10-27-2010, 12:39 PM   #4
Originally Posted by J. V. View Post
It's perfectly compliant to run a separate ground wire according to the NEC. However, the wires must be protected from physical damage and terminate at the panel board for each circuit just like a neutral must do. My biggest concern is how it passed inspection?.
I hope each set of gnds is tied to a separate circuit but don't know for sure ... so many corners were cut on the redo. As for inspection, in the aftermath of Katrina a lot of work was done without any inspection and the contractors took advantage of that. I did ask the city about permits and a general permit was pulled but no followup inspection was done ... the city waits for the contractor to call for inspection and he didn't. No automatic timeout for inspections ... not a good system.
I would have thought new wiring would be mandatory too but see above. I own the house now ... surely you don't mean shame on me. thanks
peyton
Old 10-27-2010, 01:17 PM   #5
Rewards Points: 324
i would not trust the wire.you should look for legal ways to get contractor back.your ins co probaly wont insure it any if you have it inspected.if they won't ins it give it back to bank.they are the ons getting screwed beacause till it is fixed they can't sell it.but then again???the wire is going to be wet and will detereate.just my opinion.
oleguy74 is offline   Reply With Quote
Old 10-27-2010, 01:26 PM   #6
I was more concerned about the safety aspects of it if the grounding wires are not functioning properly. Am I wrong? Thanks
peyton
LCD TV tripping GFCI breakers throughout house penleydr Electrical 34 01-27-2017 06:09 PM
GFCI breakers equivalent to GFCI outlets? Any code pitfalls? TomServo Electrical 27 02-04-2010 11:59 PM
code question - AFCI / GFCI breakers Red Squirrel Electrical 15 09-17-2009 12:16 PM
GFCI outlets or breakers? gp_wa Electrical 25 11-07-2008 08:54 PM
GFCI Breakers salty Electrical 2 07-23-2008 11:14 AM
