#1 |
Using an extension lead for a freezer in an outbuilding
Hi All,
Im needing to get a new freezer to store pet food, though have no room in the house. We have an outbuilding with no power as it was cut years ago before we moved in and would be too much trouble to try and re connect. We have a hole drilled in the wall that attaches to the outbuilding to power a CCTV unit in the animal house which works perfect. This is connected to the mains socket in the kitchen. My question is, would I be able to power a small chest freezer (suitable for outbuildings, Haier BD103GAA Chest Freezer) with an extension lead? the lead I have in mind is a 5m 13a 1 way lead, suitable for appliances upto 3000w. Please help. |
#2 |
In the USA, your set up would not be acceptable/legal.
#3 |
Sounds like you need to dig a trench and run conduit from the panel to the separate building.
#4 | |
" Euro " electrician
Using an extension lead for a freezer in an outbuildingQuote:
So you will need direct bural T&E 2.5mm2 with 16 amp RCD breaker with weather proof powerpoint. or run this in PVC conduit. If you are not sure about this just get a hold of one of the electricians in your area. Merci, Marc
The answer will be based on NEC ( National Electrical code ) or CEC ( Cananda Electrical code ) or ECF ( Electrique Code France ) |
#5 |
On top, your CCTV signal will be so poor from cross talk( EM interference from higher voltage line
) that you'd end up removing it anyway.
#6 | |
A "Handy Husband"
| Display Modes | |
| ok ric , lets see if you know | ltd | Painting | 5 | 09-07-2012 11:36 AM |
| Kenmore 596 bottom freezer cold top warm | klimshelf | HVAC | 2 | 03-30-2011 09:32 AM |
| Lead Drain Pipe Project | Turbo98 | Plumbing | 33 | 01-30-2011 12:27 PM |
| Extending extension lead | glunks | Electrical | 2 | 07-31-2010 09:32 PM |
| Getting shocked by multiple metal items in room | thms | Electrical | 14 | 06-24-2010 02:23 PM |
