#1 |
using existing wires for smoke detectors
I hardwired in BRK's throughout the house in 2002. I was going to replace all of the detectors with new ones in the coming year but I have decided to use the fire zones on my security system and install all new low voltage detectors which are much less prone to false tripping than line voltage type. I am planning on running new 18/2 fire alarm cable but I was wondering if it would be acceptable to disconnect and remove the 14/2 NM from the power source and run the fire alarm cable from the alarm panel in it's place. I would then use two of the conductors in the remaining 14/3 NM (red and black capping off the white conductor) throughout the house for the low voltage detectors. Any technical or code reason why I should not do this?
#2 | |
Lic Electrical Inspector
using existing wires for smoke detectorsQuote:
All responses based on the 2011 NEC. If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Please check with local, county and state officials as laws may vary. Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
#3 |
I know the local code they do not have to remain.
#4 | |
JOATMON
Well....a simple internet check came up with this....
So....I guess you can do what you want....since you already know the code.....
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 |
Thanks for the replies. I am not asking about detector requirements or placement. I have a photoelectric smoke inside every bedroom as well as one in the hallway within ten feet of each bedroom doorway. I could have installed only one in the hallway and have met the code but I put one inside of every bedroom as well. CO's are allowed to be separate from the smoke detectors and can be either battery, hardwired, or the plug in type. We have a plug in type on every level of living space within the home as allowed by Mass Law as well as the local AHJ.
I am asking about using the NM conductors for the low voltage smokes or if it would not be allowed to use such a cable and if I would be required to pull new 18/2 fire alarm cable. Last edited by teamo; 10-14-2012 at 11:30 AM. |
| Display Modes | |
| Electrical wiring/ switch wiring - mixed wires | tien009 | Electrical | 1 | 07-21-2012 11:53 PM |
| Two black wires and two white wires in a ceiling | mshaw11 | Electrical | 6 | 07-11-2012 10:57 PM |
| Should I install 5/16" over existing 3/4"? | AMass44 | Flooring | 0 | 03-05-2012 11:05 PM |
| replacing an existing 1-way decora light switch with a dimmer switch | maljeff | Electrical | 3 | 01-11-2012 12:49 PM |
| join new crawl space CMU footing/foundation to existing CMU basement wall | CapeCod153 | Building & Construction | 4 | 08-04-2010 08:35 PM |
