Using Duct Seal Properly. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 07:10 PM   #1
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Using duct seal properly.
I am going to be using some duct seal I have never used this stuff and would like to know if I should use it on the main service in the garage and in the mobile home panel or just in the mobile home panel. Garage is not heated. Conduit goes from the the garage to the mobile home one continuous run.
rrolleston is offline   Reply With Quote
Old 02-17-2012, 07:18 PM   #2
If the conduit goes from the garage to the mobile home, then yes I would duct seal both ends of the conduit. Anywhere where cold air can get into a heated section (i.e. your conduit) you should seal to prevent frost, condensation and ice dams.
hawkeye11 is offline   Reply With Quote
Old 02-17-2012, 08:32 PM   #3
rrolleston's Avatar
Thank you. I will be sure to use it on both ends.
Old 02-17-2012, 10:14 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I use it around the outside of areas where conduit penetrates walls,on the inside of pipes I just use fiberglass insulation to seal things.
If you have access to a place that sells hvac supplies you might see if you can pick up a box of thumb gum,its easier to work with than that stiff black/grey duct seal stuff you get at box stores
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-17-2012, 10:28 PM   #5
rrolleston's Avatar
I actually used an old dryer vent hole to run the conduit through the floor and I am going to relocate that through the outside wall. Probably will have to use expanding foam for that large hole. It's safe to use insulation in the conduit?
Old 02-17-2012, 11:19 PM   #6
plummen's Avatar
Ive never had an inspector complain,its easier to work with if you ever need to remove it
Old 02-18-2012, 05:57 AM   #7
Rewards Points: 3,256
Not saying that this would happen in your application but a friend of mine started noticing a dead smell in his basement. A snake had entered his main panel through a pad mount transformer and 200' of conduit and died in there. I'm going to pay real close attention when they install my transformer to see how they seal the conduit.
zappa is offline   Reply With Quote
How to properly seal a gable vent? Lynch Roofing/Siding 3 08-05-2011 05:39 PM
Help with return air duct gasbie HVAC 4 06-20-2011 07:54 PM
Help with hvac return duct gasbie HVAC 3 06-19-2011 11:44 AM
Raising a suspended heat duct dmarek HVAC 2 04-17-2011 05:57 PM
High Low System?? alacard HVAC 8 04-07-2011 10:39 AM
