Using The Deepest Box Possible? Is It Wrong? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2010, 01:49 PM   #1
Rewards Points: 150
Using the deepest box possible? is it wrong?
I have been reading the forum and seeing that if you have 1 cable/wire to the box you would use box A. But if you have 1 cable/wire coming in and 1 going out you would use box B? So on and so depending on how many wires/cables coming in and or going out, you may go up to box F?! My question is even if right now I only have 1 cable/wire coming in and none going out, is it wrong and why to use Box F? I would think more room couldn't hurt? But ??????
Evil Scotsman is offline   Reply With Quote
Old 11-18-2010, 03:15 PM   #2
Licensed electrician
Rewards Points: 1,874
I typically install the deepest box possible. Simpler just to stock one box on the truck. I do keep different sizes of old work boxes due to differences in the wall depth.
Old 11-18-2010, 03:58 PM   #3
Nothing wrong with exceeding code
Holt is offline   Reply With Quote
Old 11-18-2010, 07:50 PM   #4
I=E/R
a7ecorsair's Avatar
You should get yourself a book that covers this topic. All boxes have a cubic inch size and all wire has a size that is used for calculating box fill. For example, 14 gauge wire is 2.0 so if the box is 18.0 cu in. then you can have 9 #14s in it but you need to allow/deduct for clamps, devices, and other things that go into a box.
12 gauge wire is 2.25 so an 18 cu in box will only hold 8 of them.
a7ecorsair is offline   Reply With Quote
Old 11-18-2010, 08:12 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
those deep boxes go all the way to the sheathing in 2x4 walls ,imo the backs should be plated to prevent siding nails penetrating the backs of them
Tom Struble is offline   Reply With Quote
Old 11-18-2010, 08:12 PM   #6
Only downside is if the box is up against the outside sheathing
Then you have an uninsulated "hole" to the outside
With a 2x4 wall I was able to fit some rigid insulation behind my boxes
small bathroom rough-in, see anything wrong? Bobiggs Plumbing 13 01-24-2010 08:20 AM
What's wrong here? kbsparky Electrical 21 09-25-2009 09:18 PM
Whats Wrong Here J. V. Electrical 32 09-22-2009 10:58 AM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
