Old 11-11-2011, 11:53 AM   #1
Using BX in a shallow situation.
I've just strapped a ceiling with 1 x 2's and want to add a light fixture and wire it to an existing wall switch. Can I use BX cable as a protected cable and a saucer box before we install the new drywall ? Only the BX would be entering the box. I would use an angle box connector at the back KO. Would that be code compliant ? There is no attic space to access and I don't want to break the existing old ceiling drywall.
Sammy 2 is offline   Reply With Quote
Old 11-12-2011, 10:02 AM   #2
anyone??
Old 11-12-2011, 11:09 AM   #3
liscenced electrician
Im assuming you mean mc cable. Bx hasn't been used in a very long time. It sounds like you would be fine with either mc or romex. As long as its behind sheetrock either is fine. Make sure to add nail plates where you can so nobody sinks screws or nails into your wires
jimmy21 is offline   Reply With Quote
Help - Adding a third outlet off of 1 outlet, shallow box so no pigtailing stlramscards Electrical 20 02-01-2011 08:52 PM
need shallow kitchen sink ?? SteveDonohoe Plumbing 2 11-23-2010 07:12 PM
How shallow can I adjust this rigid circular saw? darsunt Tools 2 03-11-2010 08:46 AM
Shallow wells loses prime rosberney Plumbing 20 01-26-2010 08:56 PM
Challenging situation, please help. jaes HVAC 4 07-06-2008 07:48 AM
