Using 20.3 CU. Box In 2x4 Studded Walls, Ok ? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 12:59 PM   #1
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
Using 20.3 CU. box in 2x4 studded walls, ok ?
Have a bunch of these outlet/switch boxs laying around and would like to know if its ok (pre-code) to use them in a interior 2x4 wall ?
Seams like little room on where the romex runs in to mount in a 2x4 wall, but if code says its ok, then its one less thing to buy
Box measures 3-1/4 over all and 2-7/8 from back of box to "sheet-rock stops".
Will be used in NY (if that matters).
_
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - 22x22 addition - Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 11-30-2008, 02:42 PM   #2
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
They should be fine. They are used all the time. However I am not sure as to you local code.
Pudge565 is offline   Reply With Quote
Old 11-30-2008, 09:19 PM   #3
electrician
I ran into an inspector one time that wanted nail guards on all the deep boxes that I installed because it was less than 1 1/4 inches from the back of the box to the edge of the stud. I reluctantly did it just to get out of there and I didn't plan on working in his juristiction again anyways.
The inspector was wrong, he was referring to running romex in a hole in a stud with less than 1 1/4 inches from the edge.
My point is, what you want to do is code compliant, but I know of one inspector that won't allow it.
You can't always predict what little quirks your AHJ might have.
Silk is offline   Reply With Quote
Old 11-30-2008, 10:43 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
I ONLY use 20+ cu/in 1g boxes for new work. I have never had an issue nor have have I ever heard of this being an issue. At least in my part of NY.
Old 12-03-2008, 12:33 AM   #5
iMisspell's Avatar
Rewards Points: 150
Thanks guys.
Theres only like 4 or 6 boxs which need to be in the 2x4 walls, the rest will sit in 2x6.
Being a home owner doing the work - i when out and bought a few 18cu just in case the inspector was having a bad day. Im sure there will be little things i miss or do not know which he might have a problem with, so i figure, better save then sorry with something as simple as a box.
_
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
Replace exterior walls or build false walls Medic507 Carpentry 3 11-12-2008 09:48 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
