Using 2/0 Teck Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 09:34 AM   #1
Using 2/0 teck cable
I need confirmation that I can use 2/0 copper Teck cable to run from my outside, ( fused ) disconnect to my 200 combination panel located inside the house. The cable run will be partially outside and partially inside. It's a 60 foot run and this appears to be the easiest way for a DIY. Is there a better description for this cable ?? I also need confirmation of the proper end connectors. I am working under the CEC. Thanks.
Sammy 2 is offline   Reply With Quote
Old 12-12-2011, 10:27 AM   #2
Rewards Points: 760
should be ok, you need teck connector like this TCM-125-182 for 2/0 3 conductor teck cable. If you want to save some $$$ use 4/0 aluminium teck
carmusic is offline   Reply With Quote
The Following User Says Thank You to carmusic For This Useful Post:
Sammy 2 (12-12-2011)
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 09:10 AM
hot tub wiring using teck cable acad Electrical 2 05-11-2009 10:17 PM
Teck Cable sendres Electrical 1 08-22-2007 08:52 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
