Using 14-3 Wire For Two 15A Circuits - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-30-2008, 03:27 PM   #16
my electrician was installing a phase coupler for my customer and I pulled the cover off for him before he got there.
cambruzzi is offline   Reply With Quote
Old 12-30-2008, 03:28 PM   #17
Just trying to save time. Not doing anything wrong buddy!
I'm a low volt guy!!
Old 12-30-2008, 05:07 PM   #18
Phase coupler? X10 system?
jerryh3 is offline   Reply With Quote
Old 12-30-2008, 06:03 PM   #19
Electrician
That would be my guess.
chris75 is offline   Reply With Quote
Old 12-31-2008, 07:21 AM   #20
When is fishing season?
CowboyAndy's Avatar
Originally Posted by williswires View Post
Whirlpool baths, a.k.a. "hydromassage tubs" in the 2008 NEC, require GFCI protection, and that GFCI must be readily accessible.
So, you have a choice of GFCI receptacles under the tub that must be readily accessible, or GFCI breakers at your panel.
(680.71 NEC)
Also note that a traditional gfci breaker will not work in a MWBC setup. A 2-pole gfci breaker has to be used.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 12-31-2008, 08:59 AM   #21
DIYer
For me that's a good enough reason to avoid them, you'll regret it later if you ever upgrade into a code cycle that requires AFCI/GFCI and double pole MWBC breakers.
Gigs is offline   Reply With Quote
Old 12-31-2008, 09:03 AM   #22
Electrician
ITs not rectroactive, meaning you dont have to change things becuse the codes change. I have no AFCI's in my own home, and I doubt I ever will.
Old 12-31-2008, 10:48 AM   #23
Please excuse my ignorance on the subject but...
If I'm picturing things correctly, wouldn't this require two separate circuits to share the same neutral?
PirateKatz is offline   Reply With Quote
Old 12-31-2008, 10:56 AM   #24
X10 is outdated technology. The signals are weak and the systems fail quite frequently. Ive found the UPB system to work much better. The signal is 20 times stronger and each system has its own id along with each device which makes interference rare. the coupler joins the 2 phases in the house together so the signals can travel to devices on both phases.
Old 12-31-2008, 09:10 PM   #25
CowboyAndy's Avatar
Yes, thats exactly how it works.
MY HOUSE OWNS ME!
replacing old wire on existing circuits... red86yota Electrical 9 12-08-2008 06:00 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
