Old 05-25-2012, 11:28 AM   #1
Using 14-3 wire and not connecting the red wire OK?
Hi All,
I purchased wire for a basement bathroom project which consisted of connecting a new light fixture and vent fan to an existing switch in the bathroom.
Not fully understanding the 14-3 meaning, I purchased this wire thinking there were 3 wires including the ground. I realize now, this is the number of wires not including the ground.
My question is if it is OK to use this wire and simply not connect the red wire to anything? I can't seem to find any specific information about this.
Thanks in advance.
jeffdoubleyou is offline   Reply With Quote
Old 05-25-2012, 11:30 AM   #2
Licensed electrician
As long as you are less than the box capacity with conductors you are fine. Just cap at both ends.
Old 05-25-2012, 11:34 AM   #3
Awesome. Thanks for the fast reply.
Old 05-25-2012, 01:56 PM   #4
A "Handy Husband"
rjniles's Avatar
Since you are connecting to existing wiring, verify the amperage rating of the cicuit you are connecting to. Usually baths are wired with 20 amp circuits and you will need #12 wire and not #14. If your cicuit is 15 amp, the wire you bought is OK.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 05-25-2012, 08:50 PM   #5
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If you have not used it maybe you can return if it was not cut wire. I have used xx-3 wire in some areas of my home example switch box on both sides of the door total of five switches and was not sure what ones I wanted where so I ran 14-3 in case I wanted to move one to the other side in the future.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
