Using 14/2 Wire On 20 Amp Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2007, 02:10 AM   #1
Question
Using 14/2 wire on 20 amp circuit
"Hi, I have seen some remodelers with an existing receptacle that is wired with
12/2 and on 20 amp breaker tap into it with 14/2 wire to add a switch and
new fixture. Is this up to code or is only 12/2 allowed on the 20 amp
breaker? Can this 20 amp breaker be downsized to 15 amp to prevent any
overheating or is no smaller gauge wire allowed on a 20 amp circuit?
Any information on this would be appreciated. Thanks
mohairy is offline   Reply With Quote
Old 12-29-2007, 06:26 AM   #2
Electrician philosopher
12/2=20A
14/2=15A No exceptions. (well a few...but none that pertain to you.)
You can downsize the breaker to fit the 14 AWG wire.
Andy in ATL is offline   Reply With Quote
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 08:23 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
HELP with Arc Fault Circuit Interruptors! samf Electrical 3 11-24-2006 10:56 AM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
