Using 12-2-2 For Multiple Runs - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2012, 11:06 AM   #1
Rewards Points: 186
Using 12-2-2 for multiple runs
So after reading about 12-2-2 I'd like to use it for a couple of runs, and I just wanted to make sure that my plan is ok. Basically for each bedroom I'm going to have 2 circuits, one for receptacles and one for lights, so I thought I'd run one 12-2-2 to the first receptacle and break the 2nd leg off for the switch (above) and continue on. Anything I need to take into consideration? I'm going to make sure I have enough space inside the junction box to house 3 circuits, and continue the single ground wire to the next outlet (I assume there is just 1 ground wire in 12-2-2).
The main benefit as I see it is for long runs if I'm going to have multiple circuits at the end of the run, but just didn't know if there was gotchas besides the space in the junction box issue? I assume I can just break them out into separate breakers in the panel. Each room will have a 20 amp receptacle circuit for window a/c units, but 12-2 is probably overkill for a single bedroom's lighting circuit (plus ceiling fan), but I'd rather just stick with 12-2 instead of switching to 14-2 for consistency.
It's also kind of a pain to find, so far no home depot or lowes, so I guess I'll have to stop by an electrical supply house, which I'm thinking cost wise may be a more than home depot/lowes?
Thanks, Bill
Ocelaris is offline   Reply With Quote
Old 12-09-2012, 11:52 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
12-2-2 cable costs $220 at Home Depot. 12-2 costs $75 (both 250' rolls.
Cheaper to go with a roll of 14-2 and a roll of 12-2.
Coastal South Carolina
Old 12-09-2012, 12:50 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
cheaper to just run one circuit for two bedrooms, all on 14 AWG.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
Rochsolid (12-09-2012), TTW (12-09-2012)
Air Handler Blower runs for 20 seconds then stops for 3 seconds JohnRoss HVAC 13 02-12-2016 10:53 AM
Enlarging two 6" runs Rewound98 HVAC 17 01-10-2013 02:44 PM
Low Voltage Conduit Runs cphillipsmcp Electrical 9 02-08-2012 02:56 PM
insulating and insulated duct runs hummer4x4guy HVAC 4 01-09-2012 03:52 PM
runs and sanding oscarMadison Painting 1 02-24-2009 06:46 AM
