Useing Raceway For Outdoor Use? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2009, 04:42 PM   #1
useing raceway for outdoor use?
I want to add an outlet on my front lawn, I installed a brick wall and want to install lights under the lip of the wall. I got a price of 825.00 to run it under ground and i cant afford it now so I went to lowes and got 14-2 OUTDOOR gray wiring, also got a GFI and weatherproof box and cover. My question is can i use raceway and come out of a hole from my garage and attached to another wall run along the outside wall to the lawn?
trialNerror is offline   Reply With Quote
Old 04-28-2009, 07:38 PM   #2
dSilanskas's Avatar
Yes you can but I would suggest using 1/2" PVC as the raceway
dSilanskas is offline   Reply With Quote
Old 04-28-2009, 09:19 PM   #3
I've never heard of any raceway being approved for outdoor use
And I doubt it is rated for protection
There are very specific rules regarding installation, burial depth etc
The cover must be the newer in-use wet cover
Old 04-29-2009, 04:29 AM   #4
dSilanskas's Avatar
Ummm PVC, RMC, Liquid Tight, etc...
Old 04-29-2009, 03:30 PM   #5
Pvc
The only reason i didnt wanna go with PVC was cause it will be seen and wont look that good in the middle of my wall, the reason i wanted to go with the raceway was cause its smaller and after painted and clear caulked wont be noticed that much.
Old 04-29-2009, 03:37 PM   #6
Licensed electrician
Rewards Points: 1,876
The raceway you posted will rust out very quickly and I am not sure if it is even listed for exterior use.
PVC can be painted or you could bury it so it will not be seen.
Old 04-29-2009, 07:31 PM   #7
dSilanskas's Avatar
You can paint PVC.
Old 04-29-2009, 09:47 PM   #8
ummm...................The picture he posted is internal raceway
how to add a outlet bos useing 12/3 wire? iambill Electrical 8 04-14-2009 06:13 PM
Useing 20A receptical in place of a 15a Doug Crf Electrical 7 04-28-2006 08:23 PM
