Old 01-19-2013, 12:52 PM   #91
Licensed electrician
used old fuse box as junction for new breaker box
Originally Posted by hohadcr View Post
My take on this is: Most electricians are educated in school with the standard parts and equipments. They don't think beyond the normal gears to see what really is the code, how to calculate voltage and current and find out if something is really up to code. They only know what they use in class and what they buy from their supply stores.
Thus, the solution we came up with here is foreign to them. They don't even bother to check if this foreign thing is good. They just say NONONO!!
Damm... I wasted all the effort and money... I still need to pay an electrician to redo all the work!!!!
Look at all the time we waste here guys. All we need to do is that simple stuff like voltage and current calculations.
Speedy Petey (01-19-2013)
Old 01-19-2013, 02:36 PM   #92
hohadcr's Avatar
Right now, insurance company's inspector is asking for an electrian's write-off. So far, two electricians looked at it and basically said it has to be redone or no way i will pass it.
They don't bother to show me the codes... either let them redo it or good luck finding one electrician who will be willing to check all the codes and pass it.
hohadcr is offline   Reply With Quote
Old 01-19-2013, 02:40 PM   #93
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Can you post pictures of the junction box you have and let us try to help you?
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-19-2013, 02:42 PM   #94
rrolleston's Avatar
Most electricians will refuse to sign off on someones work. You may have to get an electrical inspector to sign off on your work.
Old 01-19-2013, 03:19 PM   #95
Licensed Electrical Cont.
Speedy Petey's Avatar
Let me get this straight. You are looking for an electrician to sign off on your work???
I was wondering why an electrician was involved. No, they don't have to tell you anything. If they look at it and don't like what they see that can just walk.
Personally, when someone calls for this kind of thing, and they do, I just tell them no over the phone. An electrician would be out of his mind to put his name on someone's DIY work.
WHY are you doing it this way anyway? Why not just get it inspected yourself?
Old 01-19-2013, 03:55 PM   #96
I guess I can't see why you are insisting on doing this a non-standard way when the standard is easy, inexpensive, and proven safe.
I had to turn an old panel into a junction box about a year ago. It wasn't hard and didn't require anything that can't be found in the electrical aisle at any big box store.
I really think that you should just pay someone to do this work for you. This isn't the sort of thing you want to experiment with.
dftc is offline   Reply With Quote
Old 01-19-2013, 04:31 PM   #97
hohadcr's Avatar
Back then, all electricians quoted $1200+ to do the work, with a lot of plus plus plus if ....
I got to the bottom of it and did it myself. Well, material cost a lot more than I thought.. Just a new panel box was $$$...
Now, insurance wants electrician to write off it. Electrians won't write off it....
Basically, this world has evolved that you shouldn't do anything yourself... Always need to rely on others just to be accepted in the system..
Thank you guys for replying to the thread. I myself is very disappointed with the evolvement ...
Old 01-19-2013, 04:37 PM   #98
rrolleston's Avatar
You could hire an electrical inspector to inspect your work. And you could post pictures here so we can see if we notice anything that should be done different.
Old 01-19-2013, 06:29 PM   #99
Well, you can blame your insurance company for all this then. There is no "system" to be accepted into. The electricians and inspectors have nothing to do with your insurance company. In fact, I find it VERY questionable that your ins co is asking for this. Really what they are asking for is someone to blame if something goes wrong.
Old 01-19-2013, 06:30 PM   #100
Apparently that's not good enough for his ins co.
Old 01-19-2013, 06:45 PM   #101
Licensed Electrician
k_buz's Avatar
I am itching to see pictures.
Location...Location...Location
The Following 3 Users Say Thank You to k_buz For This Useful Post:
jbfan (01-19-2013), Jim Port (01-21-2013), Speedy Petey (01-19-2013)
Old 01-21-2013, 11:54 AM   #102
Originally Posted by k_buz View Post
Its been a very long time since I looked at the specs of a wirenut, but every standard wirenut is rated for 600V and does not have an amperage rating. If I remember correctly, a standard red wirenut can fit 2 #8's which would be good for 50A.
I know that I have some that I've been avoided using in fluorescent ballast replacement because they are not rated to 600V. It is kind of a PITA to remember. IIRC, the lesser ones are rated 300V. Yea, I know, they'd probably be fine
ionized is offline   Reply With Quote
Old 01-21-2013, 12:26 PM   #103
Baby blue wire nuts are listed at 300 volts.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 01-21-2013, 08:38 PM   #104
My god what a thread! But back to an earlier point. In my county, we use a 2 out of 3 rule for meter, panel, and SE cable. If you replace only one, they'll grandfather most things that are not up to current code on the other 2. If you replace 2, you have to replace the third. Makes sense to me (and it saved me a pile of work because my very long SE cable is 3 wire, not 4.) Is that policy unusual?
philS is offline   Reply With Quote
Old 01-21-2013, 10:26 PM   #105
rrolleston's Avatar
All SE cable is 3 wire. SER cable is 4 wire
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 07:27 PM
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 11:13 PM
AFCI breaker constantly trips gdweaver Electrical 18 03-06-2010 03:12 PM
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 08:20 AM
Breaker problem jdhar Electrical 11 06-10-2009 02:18 AM
