Old 08-09-2012, 04:21 PM   #61
hohadcr's Avatar
Exclamation
used old fuse box as junction for new breaker box
Where can I find something like "Polaris pre-insulated connectors " ?
Looked at HD, radioshack, Amazon.com.... Couldn't find any.
Called local electrical supply store, they said that those connectors sold very fast, they hadn't had them in stock for a long time.
So.. help!!
hohadcr is offline   Reply With Quote
Old 08-09-2012, 04:26 PM   #62
hohadcr's Avatar
Why c an't I buy connectors like those in the breaker boxes?
I am going to run around to all the small suplly stores tomorrow to see what they have!
Old 08-09-2012, 05:01 PM   #63
Licensed Electrical Cont.
Speedy Petey's Avatar
You need to find a supply house that is smart enough to restock something that sells out really fast.
Or try the internet.
Old 08-10-2012, 02:53 PM   #64
hohadcr's Avatar
found a connector like the pic below. They have different sizes rated for up till 100amp, 600volt. The guy in the store was not sure if these connectors are allowed as home electrical connectors.
To wrap up my question: Can I use this kind of connector to extend wires from 110, 15amp wires up to the main power supply, 100amp wire?
Any one knows?
Old 08-10-2012, 03:07 PM   #65
Licensed electrician
I would like to know why the supply house thought you could not use wire nuts.
Old 08-10-2012, 03:13 PM   #66
hohadcr's Avatar
The store helper is just a "helper". He thought it was from the section of "automobile", so it should not be for home electricals.
That's why I would like to ask some real electrician.
Old 08-11-2012, 11:30 AM   #67
hohadcr's Avatar
anyone anyone? Can I just the connectors in the pic above?? anyone pls?
Old 08-11-2012, 08:22 PM   #68
hohadcr's Avatar
anyone can help ? thx
Old 08-11-2012, 09:01 PM   #69
Missouri Bound's Avatar
NO
Those are rated for use in automotive / marine / low voltage applications. Use wire nuts.
Do you want it your way or the right way?
Old 08-11-2012, 09:39 PM   #70
Originally Posted by Missouri Bound View Post
NO
Seriously? You've never seen those in control panels and boards?
They are certainly for line voltage use (hence the 600V rating). They should be mounted/secured in place (just my opinion).
Old 08-11-2012, 09:40 PM   #71
Any one knows?
WHY not just get Polaris splices for the bigger wire and wire nuts for the smaller????
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (08-12-2012)
Old 08-11-2012, 09:56 PM   #72
hohadcr's Avatar
Can anyone post a picture of something of "Polaris splices"?
I can't find it in local supply stores... nor on amazon.com
Old 08-11-2012, 09:58 PM   #73
E2 Electrician
stickboy1375's Avatar
Just buy split bolts... gezz... 100 page thread going on here.
stickboy1375 is online now   Reply With Quote
The Following User Says Thank You to stickboy1375 For This Useful Post:
Missouri Bound (08-11-2012)
Old 08-12-2012, 06:45 AM   #74
Right from the Google link I posted above: http://www.aplussupply.com/nsipolari...connectors.htm
Old 08-12-2012, 06:47 AM   #75
While these are sometimes easier to get, I am always afraid of DIYers taping up bugs. I have seen some scary bug taping jobs in my day, and one actually put me out of work for two weeks.
k_buz (08-12-2012)
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 07:27 PM
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 11:13 PM
AFCI breaker constantly trips gdweaver Electrical 18 03-06-2010 03:12 PM
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 08:20 AM
Breaker problem jdhar Electrical 11 06-10-2009 02:18 AM
