Used Old Fuse Box As Junction For New Breaker Box - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-27-2012, 11:09 PM   #31
Gymschu's Avatar
Rewards Points: 836
Originally Posted by Speedy Petey View Post
Really? And you have this on good authority?
You've seen it happen? Did the insurance police come knocking asking to see your fuse box?
WHY would the insurance company even be aware of this??????
Yes, I was told I had ONE week to remove the fuse box or the insurance company would drop me. It has happened to numerous homeowners in my surrounding area and includes all the name brand ins. companies.
Gymschu is online now   Reply With Quote
Old 07-28-2012, 06:33 PM   #32
Missouri Bound's Avatar
That is complete bullsh*t on the insurance conpanies part. Find a new insurance company. Absolutely nothing wrong with fuses.
Do you want it your way or the right way?
Old 07-29-2012, 08:23 AM   #33
How did they know you had a fuse box?
Eds_tls is offline   Reply With Quote
Old 07-29-2012, 08:25 AM   #34
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
It's a liability they don't want, you know damn well people install the wrong size fuse all the time, you know how many 30 amp fuses I find installed on a 15 amp circuit?
Never mind the countless pennies and other foreign objects used to complete the circuit.
I don't blame the insurance company one bit! And I really don't think you will find a insurance company that doesn't follow this protocol.
Old 07-29-2012, 04:33 PM   #35
Gymschu's Avatar
Rewards Points: 836
Every insurance co. I know sends out an inspector before insuring your home. This happened many years ago and it still happens. My nephew recently bought a home and his future ins. co. said they would not insure the home if the roof was more than 15 years old!
Old 07-29-2012, 04:37 PM   #36
E2 Electrician
You have to remember, insurance companies, like ANY company, are out to make money, so if they are always paying claims, that company will fail, it's all about good investing, and they tend to increase those odds or walk... We all do the same thing in life.
Old 07-29-2012, 05:08 PM   #37
It's not much harder to install a larger breaker than to insert a larger fuse. It's certainly easier and safer to install a breaker than to shove an object into the fuse base.
Phildaglass is offline   Reply With Quote
Old 07-29-2012, 05:10 PM   #38
E2 Electrician
seriously? you dont think its MUCH more likely to simply unscrew a fuse and screw a larger size in its place? 9/10 times the circuit is already overloaded due to its original installation date and much heavier loads that we have today.
Old 07-29-2012, 05:13 PM   #39
If someone is having a problem and they are willing to hack it, I don't see it being that much different. I have personally found many #14's on 20A breakers in my time.
Old 07-29-2012, 05:14 PM   #40
E2 Electrician
You're missing the point i'm afraid.
Old 07-29-2012, 05:17 PM   #41
I don't think so.
You are saying that fuseboxes are bad because people can use larger fuses or insert objects into the socket. I said that people can easily use larger breakers in a modern panel for the same effect.
What's the difference between someone going to Home Depot and picking up a larger fuse and them going there and picking up a larger breaker?
Old 07-29-2012, 05:26 PM   #42
E2 Electrician
I don't think so.
This is obviously too hard for you to grasp, when a fuse blows they need to change it, most likely they are going to install whatever size they have laying on top of the panel, weather it be a 15, 20 or 30, not until 1968 did the NEC mandate that type 'S' fuses be used, these are not interchangeable because of the thread size...
You are talking about something that is not the same as I am. The LIKELIHOOD that the incorrect size fuse gets installed is MUCH higher then the scenario you describe.
Old 07-29-2012, 05:33 PM   #43
Wow, good job acting like an adult. Is something that I said really that bad that you had to insult me? Is that acceptable here? If I knew that people would be childish and insulting when they disagreed with you I would have chosen another forum to join.
We are talking about the same exact thing. Not everyone has fuses sitting on top of their panel nor do they have larger fuses than their typical branch circuits. It's very likely that they would have to go out to the store to buy a fuse, and that is not so far off from going to the store to buy a breaker. In both cases, someone can instal a larger OCPD.
Whether it's a fuse box or breaker panel, if someone is overloading a circuit and facilitating the use of the OCPD, they can (and many times will) install a larger model.
I simply do not share your opinion that a fuse box is more dangerous than a breaker panel solely because someone can install a larger OCPD.
And that is what I disagree with. If someone is willing to go buy a larger fuse, then they would most likely also be willing to go buy a larger breaker. I have backed up my opinion with real world experience.
Old 07-29-2012, 05:34 PM   #44
E2 Electrician
and I apologize if you took my words to strongly to heart, it was not my intent to belittle you.
Old 07-29-2012, 05:37 PM   #45
Well, the insurance company agrees with me.
I'm not sure what "the insurance company" is. MY insurance company doesn't agree with you. No insurance company that I know of does either. If one that you use agrees with your position, then that is fine, but I do not base my opinions off of insurance companies.
I've had many jobs removing old disconnected knob and tube wiring just because an insurance company said it can't be there. It cost the homeowner a lot of money to have all traces of it completely removed, the insurance company didn't care if it was completely disconnected by a licensed electrician, they wanted it removed.
Insurance companies aren't the end all be all of electrical work.
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 06:27 PM
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 10:13 PM
AFCI breaker constantly trips gdweaver Electrical 18 03-06-2010 02:12 PM
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 07:20 AM
Breaker problem jdhar Electrical 11 06-10-2009 01:18 AM
