Old 07-24-2012, 03:21 PM   #1
hohadcr's Avatar
used old fuse box as junction for new breaker box
I have a fuse box for a part of the house. I would like to add a breaker box.
I am going to just use the old fuse box as a conjunction box, and add the breaker box on it.
My questions is:
how exactly am I going to do the wiring for this fuse box/conjuction box?
Do i keep the fuses in the fuse box?
hohadcr is offline   Reply With Quote
Old 07-24-2012, 03:47 PM   #2
Electrical Contractor
Best way is to remove the guts of the old panel.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 07-25-2012, 12:52 PM   #3
hohadcr's Avatar
Thanks jbfan,
Can you elaborate? Remove the "guts" of the old panel?
How do I connect the wires between the old fuse panel and the new breaker box?
How to put the wires in after the fuses?
Old 07-25-2012, 04:08 PM   #4
hohadcr's Avatar
Do I buy all new relays and install them in the old fuse box?
thx
Old 07-25-2012, 06:31 PM   #5
Julius793's Avatar
remove everything from the fuse box, buses fuses till is just an empty box with wires coming in. then extend evey wire with wire nut to your new panel.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 07-25-2012, 06:33 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Why would you want to do this? Just install the breaker panel where the fuse box is.
I see and hear this a lot, but I cannot understand the logic of it.
Old 07-25-2012, 06:39 PM   #7
Julius793's Avatar
if you want the new panel in another location
Old 07-25-2012, 08:14 PM   #8
E2 Electrician
stickboy1375's Avatar
I've done this because some knuckle head installed the panel in a crawl space, then the woman put an addition on with a full basement, she didn't want the OCD's in the crawlspace anymore.
stickboy1375 is online now   Reply With Quote
Old 07-25-2012, 08:19 PM   #9
Licensed Electrician
k_buz's Avatar
Around these parts, you cannot just remove a fuse box and install breakers in their place. You would need to update the grounding, and if you update grounding and the panel, you would be required to update the meter socket as well.
Legal panel changes are few and far between around here.
Location...Location...Location
The Following 2 Users Say Thank You to k_buz For This Useful Post:
gregzoll (03-17-2013), Hardway (01-19-2013)
Old 07-25-2012, 08:23 PM   #10
E2 Electrician
That is insane..... the requirement I mean.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 07-25-2012, 08:35 PM   #11
I agree, that's just messed up.
Old 07-25-2012, 08:35 PM   #12
Gymschu's Avatar
I cannot imagine that your insurance company would sign off on this.
Old 07-25-2012, 08:36 PM   #13
Now this I get.
I meant just using the fuse box as a splice box and putting a panel right nearby.
Old 07-25-2012, 08:36 PM   #14
What does the insurance company have to do with it???
Old 07-25-2012, 08:36 PM   #15
E2 Electrician
Now this I get.
Right, I dont get that either....
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 07:27 PM
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 11:13 PM
AFCI breaker constantly trips gdweaver Electrical 18 03-06-2010 03:12 PM
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 08:20 AM
Breaker problem jdhar Electrical 11 06-10-2009 02:18 AM
