Old 08-27-2012, 12:27 PM   #1
Use last switch in 3 way for power to separate lights?
Hi,
I have a three way switch. The config is power running to switch 1 which then runs to light fixture and then to switch 2. I have a totally separate light that needs power. Is there a way to pull power from switch 2 in my 3 way or do I have to run a line back into switch 1 and tail the light before it even gets to switch 1. Just looking to save some wiring but also want to be safe and follow code. Thanks.
Mike
heyjoe91 is offline   Reply With Quote
Old 08-27-2012, 12:41 PM   #2
no, I don't believe so. I believe the only unswitched power you have is at switch 1.
oberkc is offline   Reply With Quote
Old 08-27-2012, 12:55 PM   #3
Thanks. That is what I thought but just wanted to make sure. I've done a ton of electrical work but not much with three way switches.
Old 08-27-2012, 01:20 PM   #4
Are you sure switch #1 has the ALWAYS HOT conductor at the common terminal and switch #2 has the switched hot? Is this your setup??
hammerlane is offline   Reply With Quote
Old 08-27-2012, 01:51 PM   #5
This looks like my setup. Only difference (doesn't really make a difference) is that instead of an outlet in the middle it is a light. Switch #1 has a black and white coming from the breaker. The black is actually tailed off for a few other outlets. There is 14-3 coming from the light (I'm assuming since I didn't take down the light). Switch #2 has only three wires coming into the box so I'm assuming they are coming from the light. Does this make sense?
Old 08-27-2012, 02:04 PM   #6
that was a diagram I had on my computer...yes as you guessed outlet or light doesnt make a difference....still a device
Old 08-27-2012, 02:06 PM   #7
So with this setup is there no way to pull power from the last switch and run a completely independent switch and light?
Old 08-27-2012, 02:13 PM   #8
No. You have no constant power at switch #2 and no neutral.
Old 08-27-2012, 02:26 PM   #9
Thanks so much for you help. Much appreciated.
existing switch for new lights eatonjr907 Electrical 16 04-23-2012 02:09 PM
4 way switch setup with multiple runs of lights CapeCod153 Electrical 23 03-28-2012 03:27 PM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 12:45 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 10:25 PM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 06:04 PM
