I was going to drill into some concrete and use tapper screws, but the bit wouldn't go through, I decided to use some construction adhesive rated for metal to concrete. After 29 hours, its hard as a rock. Is it ok to use this as a securing method? (This box is in an old work install)
I used liquid nails along with the nail in plastic boxes on my last job here at home. No way they will ever come loose. Could be a bad thing if you think about it.
Thats good to know. The masonry was thicker than I thought...The 1/2 inch bit went through it like butter while the 3/8 (I think) bit did not want to go through it at all.
Are you using a hammer drill or just a standard power drill? I found a cheap "Tool Shop" brand hammer drill for 30 bucks at a local Menards home improvement center here. Its cheap and if it breaks then no big deal; it has served my occasional concrete drilling purposes just fine and its still working. I wouldn't use this on a daily basis or for a ton of concrete drilling, but for the small jobs its perfect (and cheap too).
Something to keep in mind. A hammer drill, drills the hole evenly and will not enlarge the hole by operator misalignment. Using a regular drill can cause the hole to be wider than required and then your anchor strength could be compromised. The reason I bring this up is due to the instructions that come with most concrete fasteners.
The best reason is, IT's EASIER!!!!
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
