The Use Of Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 10:13 AM   #1
seansy59's Avatar
Rewards Points: 258
The Use of Conduit
Well, I have 2 questions related to conduit. So I though I would combine the two into one. I just wanted some opinions, since there is really no code to follow with these. We have a 1 story home with just a crawlspace.
1) I installed a sprinkler system a few months back. And it works great! Only problem is animals chewing on the control wire going to the boxes. The timer is mounted in a spare bedroom on the wall just outside the sprinkler boxes. The wire runs down into the crawlspace through the floor and right outside the vent underground for about 10ft. Since it said direct burial, thats what I did.
Well, now I am sorry I DID direct bury, due to animals and moles.
Can I put this in small conduit to go from the crawlspace vent, to the valve box so animals stay away?
2) Same room location, except speaker wire this time. Same path, and it goes around the corner of the house to some outside speakers on wooden poles.
Put speaker wire in small conduit (seperate from sprinklers) from vent and up the pole to the speakers?
seansy59 is offline   Reply With Quote
Old 08-09-2011, 10:49 AM   #2
Rewards Points: 320
If the animals are a problem then yes I would put it in conduit. Are they getting into the valve box or just chewing the wires that run underground to the box? The speaker wires can also go in the couduit without any problem.
teamo is offline   Reply With Quote
Old 08-09-2011, 10:58 AM   #3
seansy59's Avatar
Rewards Points: 258
Nope, the box is fine. I made sure to seal the holes and bottom. Its moles and squirrels, chipmunks, etc that are chewing on it where its above ground for the only foot from the vent to dirt, and the 10ft run to the boxes.
Thanks! I'm goin' to get the conduit now.
Old 08-09-2011, 02:48 PM   #4
Missouri Bound's Avatar
You are using PVC, correct?
Old 08-09-2011, 03:18 PM   #5
seansy59's Avatar
Rewards Points: 258
YUP! It's actually 100% done now. (At least the sprinklers)
Speaker wire tommorrow I hate digging........
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Its glued with conduit cement too.
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
What conduit should I use? mulltron Electrical 6 07-12-2011 01:34 AM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 12:50 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 01:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
