USE Cable For Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2009, 08:01 AM   #1
USE cable for sub panel
I am planning on putting a 100 amp sub panel in my basement. The main load center is in the garage about 40 feet away. I was hoping to use Southwire 27282306 USE cable for the 2 hot conductors in a 1" PVC conduit plus the ground and a neutral wire (i am thinking #4 or #6 copper for the ground and neutral wires but I am not sure on that aspect) Can this number 2 aluminum wire be used in a conduit since it is rated as Direct Burial? Any help in this matter would be greatly appreciated. Thanks Carl.
carlb23 is offline   Reply With Quote
Old 10-19-2009, 08:47 AM   #2
Licensed electrician
Rewards Points: 1,738
You should just get SER cable. Depending on which code cycle you are under will effect the proper cable size.
Old 10-19-2009, 09:03 AM   #3
Yes i was going to use the SER cable but I thought since my friend had a 500 foot spool of #2 USE I could save some money by not having to buy the SER. Is USE acceptable to use in conduit in the house? Carl
Old 10-19-2009, 09:46 AM   #4
USE is underground service entrance cable. It is not for use in the interior of a house.
Old 10-19-2009, 10:06 AM   #5
Thanks, I will get some SER Carl
Proper cable entry into breaker panel tns1 Electrical 12 08-26-2009 11:25 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Sub Panel SoxFan Electrical 2 12-02-2008 10:16 AM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
