Old 09-03-2012, 02:20 PM   #1
j_sun's Avatar
Use a 20VAC trans for a 16VAC doorbell?
Hi,
I picked up a new doorbell and it says it requires a 16VAC txfmr. The doorbell I am replacing uses a 20VAC one. Is there typically a tolerance on these doorbells or do I need to get the exact voltage they are saying? (Which, not surprisingly, seems to be only made by the same company)
Thanks,
Jason
j_sun is offline   Reply With Quote
Old 09-03-2012, 02:45 PM   #2
E2 Electrician
stickboy1375's Avatar
Originally Posted by j_sun View Post
Hi,
Thanks,
Jason
If the manufacture says 16 VAC, then I would stick to that voltage. They probably know what they are talking about.
Old 09-03-2012, 03:00 PM   #3
JOATMON
ddawg16's Avatar
I agree with stickboy......
If it was 18Vac and you had a pretty good distance to go....ok....but at 20Vac.....unless you have small gauge wire..good chance the new door bell will not last long.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 09-03-2012, 03:06 PM   #4
Electrical Contractor
kbsparky's Avatar
Are you sure your old transformer is 20 VOLTS and not 20 VA (watts)?
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
ddawg16 (09-03-2012)
Old 09-03-2012, 03:11 PM   #5
E2 Electrician
Typical multitap transformer..
Old 09-03-2012, 07:49 PM   #6
You can use a resistor to drop that extra 4 volts !
But we need to know how much current the doorbell uses ?
Do you know ?
dmxtothemax is offline   Reply With Quote
Old 09-04-2012, 12:28 AM   #7
CLose enough for me. I bet you a doughnut that the "20 volt" transformer is at least 2 volts either way off of 20 volts.
Auger01 is offline   Reply With Quote
Doorbell bructa Electrical 2 08-29-2012 07:02 AM
Problem with wire to doorbell button. darsunt Electrical 7 03-04-2012 09:40 AM
Troubleshooting this doorbell darsunt Electrical 14 09-20-2011 01:02 PM
Doorbell Question captainron19 Electrical 21 03-05-2010 05:40 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-22-2007 12:08 AM
