Use 14/3 Two Circuit W/ Gfci Possible? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-13-2012, 09:14 PM   #16
Rewards Points: 1,514
deleted
AllanJ is online now   Reply With Quote
Old 04-13-2012, 09:20 PM   #17
The 12-2 or 12-3 is used if you want to combine the receptacles and lights and fan for one bathroom on one circuit (U.S. locations requiring 20 amp bathroom circuit.)
When you have a double wide 20 amp breaker you can use one 12-3 instead of two 12-2s. Just be sure that the breaker is positioned in the panel so you get 240 volts across the two breaker screws. (It's still 120 volts from hot to neutral.) One single wide (tandem) double breaker may not be used with the 3 conductor cable.
Old 04-13-2012, 09:25 PM   #18
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you run a MWBC (12-3), you must put those circuits on a 2P breaker or install a handle tie on 2 single pole breakers.
Tags
14/3 , gfci
GFCI in middle of circuit packer_rich Electrical 15 11-30-2011 12:38 PM
Stairway light powered from GFCI circuit? jeh179 Electrical 10 03-23-2011 08:57 AM
GFCI Outlet on 20A garage circuit campos202 Electrical 2 09-10-2009 09:38 AM
GFCI Trips campbellpt Electrical 28 11-21-2008 03:06 PM
GFCI circuit Cossack Electrical 31 03-21-2008 12:34 AM
