Old 11-16-2012, 11:00 AM   #1
USB Wall Socket
I have a lot of USB devices, mostly all of my apple products and have seen USB wall sockets that you can install into your wall that look like a normal socket but obviously with the USB hole in.
I wanted to try and do it myself but I have very limited electrical knowledge. My question is has anybody here done this before? Is it difficult.
I have contacted a local electrician (http://www.anhobsonelectrical.co.uk) in my area and I think he quoted around £30-£40 pound to do the job.
It seems like a fair price which is putting me in two minds. Is it better to pay and make sure its done properly or attempt it myself and try and learn - after all I might want to put these sockets around the house later on.
Does anybody know where to get cheap USB sockets? I want ones with 4 USB holes in if possible, if not then 2.
Thanks for any help
ckelly10 is offline   Reply With Quote
Old 11-16-2012, 11:06 AM   #2
USB Wall Socket
They're the same as installing any other plug socket - turn off the power, unscrew, rescrew. If you're not comfortable with that, then hire someone.
TheBobmanNH is offline   Reply With Quote
Old 11-16-2012, 11:34 AM   #3
USB Wall Socket
Thanks for the reply. Is it really that simple? I thought because there was other other sockets (USB) - it would involve more work as my current ones only have 2 sockets and my new ones would have 4.
Old 11-16-2012, 11:39 AM   #4
joed's Avatar
USB Wall Socket
The USB plug is part of the receptacle. It is as simple as described. There is no USB connection that will need to make.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-16-2012, 11:53 AM   #5
USB Wall Socket
Thanks Joed - I think I will brush up on my electrical knowledge and attempt this myself as it sounds like a simple task that even I should be able to do. Also as I can see myself installing these in a few rooms in my house it will work out a lot cheaper than calling in a electrician
Old 11-16-2012, 11:56 AM   #6
USB Wall Socket
Yeah, they just put a little AC/DC converter inside the switch plate to provide the 5v for the USB, but it still just connects to house power as it normally would from your perspective. Might be a little harder to work with / fit in the box as the back is likely bulkier to account for the extra circuitry, but ti's still just hot, common and ground.
The Following User Says Thank You to TheBobmanNH For This Useful Post:
ckelly10 (11-16-2012)
Old 11-16-2012, 02:10 PM   #7
J. V.'s Avatar
USB Wall Socket
USB ports do more than just charge devices. A USB port IMO should be fed with cat5 or cat 6 cable to provide network capability. I have never heard of a USB plug without connecting a network cable to it? What am I missing here? Are you just looking for USB charging or networking? If its both, than you need to run network cable not electrical cable.
Old 11-16-2012, 02:26 PM   #8
USB Wall Socket
USB charging.
Something along the lines of this. (US version, OP is UK.)
Oso954 is online now   Reply With Quote
Old 11-16-2012, 06:14 PM   #9
E2 Electrician
stickboy1375's Avatar
USB Wall Socket
Most devices are wifi... only the power portion is required. But in regards, the OP is talking strictly USB power ports only.
Old 11-16-2012, 08:00 PM   #10
USB Wall Socket
USB isn't compatible network cabling! Its different technology!
Old 11-16-2012, 08:23 PM   #11
joed's Avatar
USB Wall Socket
The USB receptacles are simply a power source for charging. They have no data capability. There is no network connection possible to them.
Here are some videos that might be useful to you.
http://www.youtube.com/watch?v=ZL15uDqHrgI
http://www.youtube.com/watch?v=eTy9EuVVTBE
Old 11-16-2012, 08:54 PM   #12
USB Wall Socket
Thanks for any help
watch this vid... http://howto.cnet.com/8301-11310_39-...b-wall-socket/
epson is offline   Reply With Quote
Wall construction for insulation support WillK Building & Construction 3 12-09-2010 02:55 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Why is this wall socket dead? darsunt Electrical 7 08-13-2009 02:19 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
