Usage Costs For In Floor Heat Wire ? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2012, 09:04 AM   #1
Usage Costs for In floor Heat Wire ?
Electrical novice here.... I think calling myself even a novice is too much credit.
The good thing is I'm not the one that did the work....
My question is about votls/amps/wats correlations.
Long sorry short ... I have in floor heating wire that was installed - this is not the typical off-the-shelf type (have a friend in the home products biz and he picked this up for me on a recent trip to china).
I am trying to estimate usage costs come winter time... but something just does not sound right to me...
It is 18W/220V heat wire...
Have 120/240 Volt Main Service
Is the calculation correct:
Power
18w per meter and i have 220 meters (700 Ft)
- total power is 220m*18w/m, if your voltage is 240V, the Amps will be 220*18/240v=16.5A.
If correct - That means this is going to be insanely expensive to run - correct?
spaceboy is offline   Reply With Quote
Old 04-23-2012, 09:12 AM   #2
Rewards Points: 2,516
18 watts per meter at 220 meters in length gives about 4000 watts.
If your electric consumption is based on the KWH(kilowatt-hour) then 4 KWHs:
at 15cents per KWH would be about 60 cents per hour,
at 12 cents per KWH would be 48 cents per hour to run,
at 9 cents per KWH would be 36 cents per hour to run.
hammerlane is offline   Reply With Quote
Old 04-23-2012, 09:14 AM   #3
Code05's Avatar
Rewards Points: 1,104
http://www.energysavers.gov/your_hom.../mytopic=10040
Code05 is offline   Reply With Quote
Old 04-23-2012, 09:17 AM   #4
I=E/R
a7ecorsair's Avatar
Your math appears correct. Your total wattage will be 3960 watts which will require a 30 amp circuit if it all runs on the same breaker.
How much do you pay for power?
a7ecorsair is offline   Reply With Quote
Old 04-23-2012, 09:37 AM   #5
EDIT...
I factoired in my taxes and delivery fees in the per kwh caculation...
my actual cost per kwh = .08
So a good estimate, if this is on about 8-10 hrs a day would be - $3.60 a day and $108 incremental monthly?
Old 04-23-2012, 09:57 AM   #6
Originally Posted by spaceboy View Post
EDIT...
Appears to be a good ball park estimate. If you really want to know, unplug everything electrical, read the meter, run only the floor heat for an hour, read meter again and see how many KW were used.
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 04:24 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
