Urgent Help Needed :) - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2016, 05:34 PM   #1
Urgent help needed :)
Hi guys new to the forum just signed up,
I currently have a rather large room with 9 Light fittings in controlled by 2 switches either side of the room how ever I've just put a couple of walls up as a projector/ cinema room and I'd like to now have a separate switch for 4 lights I know it's possible but can't find a topic as to how to do it, could someone please explain as simple as possible it would be much appreciated I have access above for cabling etc, regards
Royer89 is offline   Reply With Quote
Old 01-02-2016, 05:41 PM   #2
Civil Engineer
Rewards Points: 4,514
You can run a switch loop off an existing hot feed, or you can run a new circuit from the panel. If you don't have much experience doing electrical work, and you want to try this yourself, I suggest you purchase a book on basic electrical wiring, you can get them at any big box store. It is almost impossible to describe in detail how to do the project over an internet chat forum like this unless you have some fundamental knowledge of electric wiring. A good option would be to get someone you know who understands wiring to help you out.
Old 01-02-2016, 05:42 PM   #3
I do have basic electrical knowledge with wiring fittings etc, it's more where my new switch wire needs to run to make the 4 lights separate to be able to switch them on and off if that makes sense? Cheers
Old 01-02-2016, 09:27 PM   #4
Anyone? Regards
Old 01-02-2016, 10:03 PM   #5
Rewards Points: 198
If you run a new circuit , run your romex directly into the switch box and wire nut your whites together ,your main black feed to the bottom terminal of your single pole switch and your outgoing black of the romex feeding the lights to the other terminal .Run your romex into the first light ,hook up the neutrals and black switched wires and daisy chain to the rest of the lights from there .
daveblt is offline   Reply With Quote
Old 01-03-2016, 04:05 AM   #6
Spider to be 3 core and Earth 1.5 then not 2 core and Earth 1.5?
Old 01-03-2016, 04:07 AM   #7
So it needs*
Old 01-03-2016, 09:48 AM   #8
Rewards Points: 808
Where in Europe are you located?
IslandGuy is offline   Reply With Quote
Old 01-03-2016, 12:19 PM   #9
Northampton England
Old 01-03-2016, 02:32 PM   #10
Bump sorry need to resolve the issue
Old 01-03-2016, 03:43 PM   #11
Oso954's Avatar
Rewards Points: 400
The majority of users here are in North America. Recommendations would be based on US or Canadian codes and devices. Hence the reference to black and white wires in Romex by another poster.
I would suggest that you post to a UK based forum such as DIYNOT.com
Oso954 is online now   Reply With Quote
Old 01-03-2016, 05:20 PM   #12
ER2
Rewards Points: 70
This is fascinating. Electricity works the same everywhere, right? The terminology however is apparently quite different. I have no clue what your post means. Almost sounds like something out of a SF movie.
Obviously I am of no help but I am curious as to what your post meant.
ER2 is offline   Reply With Quote
Old 01-03-2016, 06:30 PM   #13
Oso954's Avatar
Rewards Points: 400
I think he is asking if he should use XX/3 with ground or XX/2 with ground for his wiring. The 1.5 is 1.5mm2 wire which is in between #16 and #15 AWG.
Urgent help needed! Drooping pergola challenge! house_md Building & Construction 11 07-21-2015 03:57 PM
urgent help needed installign stair rail and balusters laurenmac Carpentry 5 07-20-2015 02:17 AM
Urgent need manual or info sheet wifelover Tools 7 01-28-2015 08:42 PM
Urgent Help Needed - Ceramic Floor MarkD200 Flooring 8 08-13-2012 11:24 AM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing/Siding 6 02-20-2007 12:17 PM
