Upstairs Lights Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2010, 12:14 PM   #1
Exclamation
Upstairs Lights not working
I just changed a light fixture and too my knowledge i tthink its correct. I taped up all 3 red wires and then taped the live black wire and put the earth wires in to the light and the other two blacks into the light. Am i right in doing so?
All of my upstairs lights do not work now what have i done wrong and need to do to put it right?
XDbatman is offline   Reply With Quote
Old 02-16-2010, 12:49 PM   #2
Licensed electrician
Rewards Points: 1,630
Are you in the US or Europe?
I can tell you that tape alone is not sufficient means to make a good quality electrical connection. Twist-on connectors commonly called wire nuts should be used.
Old 02-16-2010, 01:12 PM   #3
Europe
Tags
lights , wire , wiring
Lights dim when I turn other lights on... slowjo Electrical 12 06-12-2009 08:09 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
Porch lights with timer or photocell? ciera Electrical 4 10-29-2007 07:35 AM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 05:47 PM
