Upside Down Electrical Receptacles - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-07-2013, 12:24 PM   #16
Electrical Enthusiast
Rewards Points: 504
I had a metal cover plate that wasn't screwed in correctly, went to plug something in and it fell across the hot and neutral. The light show was spectacular
Kyle_in_rure is offline   Reply With Quote
Old 09-07-2013, 12:44 PM   #17
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
Originally Posted by Daniel Holzman View Post
An upside down receptacle is easy to fix, you just stand on your head.
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
Old 09-07-2013, 02:57 PM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 2,142
Don't over look the fact that with the outlet installed 'ground up', your electrons will be reversed.
ddawg16 is online now   Reply With Quote
Old 09-07-2013, 03:17 PM   #19
Rewards Points: 504
That must be why my fan spins backwards when I plug it in an upside down receptacle....
Old 09-07-2013, 08:43 PM   #20
" Euro " electrician
frenchelectrican's Avatar
Then you have to buy a receptale reversing switch !!
Merci,
Marie et Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Kyle_in_rure (09-07-2013)
Old 09-07-2013, 08:50 PM   #21
Rewards Points: 504
Merci,
Marie et Marc
I don't think those are UL approved yet
You have to use those with AFCI breakers....
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
frenchelectrican (09-07-2013)
Old 09-07-2013, 08:55 PM   #22
Then you have to turn the house upsidedown to get it correct for you
Merci,
Marie et Marc
Electrical loading question jimcorey Electrical 2 12-08-2012 07:27 AM
Electrical diagramming questions Texas Couple Electrical 21 12-05-2012 12:26 AM
breaker panel positioning regulations orobono Electrical 1 10-27-2012 03:25 PM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
