Upside Down Electrical Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 05:17 PM   #1
Rewards Points: 155
Upside down electrical receptacles
Is it a practice that when you have a GFCI breaker at the panel you install the electrical receptacles on this circuit upside down, i.e., ground opening up?
RocketGal is offline   Reply With Quote
Old 09-05-2013, 05:31 PM   #2
Electrical Contractor
kbsparky's Avatar
Nope.
Ground up, ground down, how about sideways?
Try THIS for size:
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
HARRY304E (09-07-2013)
Old 09-05-2013, 05:47 PM   #3
Civil Engineer
Rewards Points: 4,860
An upside down receptacle is easy to fix, you just stand on your head.
Daniel Holzman is online now   Reply With Quote
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
HARRY304E (09-07-2013), oh'mike (09-05-2013)
Old 09-05-2013, 07:16 PM   #4
joed's Avatar
Rewards Points: 13,356
Code does not care about the position of the ground.
I have not that one about GFCI being ground up. I have heard the one about a switched receptacle being opposite to the others in the room to identify it as switched.
Old 09-05-2013, 07:29 PM   #5
Rewards Points: 1,016
I Prefer ground down as the are some devices and power bricks that assume ground is down else they don't fit or function well.
____________
Vince
Old 09-05-2013, 07:29 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
A) There is no such thing as an "upside down" receptacle.
It's either ground down or ground up. Both are legal and common.
B) NO, it is not practice in any place I have ever heard of.
Old 09-05-2013, 07:39 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 832
I was on a project once where an apprentice electrician was installing them "upside down". It turned out his previous project was a medical bldg and they were spec'd with ground up.
Guess he didn't know any different....
Old 09-05-2013, 07:45 PM   #8
DIY staff
Rewards Points: 7,174
I just follow what is done in the rest of the house-------left to my own choice I put them in with the ground down--or to the right if horizontal.
Old 09-06-2013, 07:26 AM   #9
Electrical Enthusiast
Rewards Points: 504
Either way it's still a receptacle.
I was recently inside a local bank and noticed they were all mounted ground up. I was surprised because most plugs seem to be more easily used with a ground-down receptacle.
Kyle_in_rure is offline   Reply With Quote
Old 09-06-2013, 08:23 AM   #10
PoleCat's Avatar
Rewards Points: 1,652
I deplore ground up mounted recepticals and refuse to use them.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-06-2013, 10:54 AM   #11
Rewards Points: 504
so you only buy ground down receptacles?
Old 09-06-2013, 01:36 PM   #12
Rewards Points: 155
I will use the proper term from now on ... ground up or ground down.
Thanks.
The Following User Says Thank You to RocketGal For This Useful Post:
oh'mike (09-06-2013)
Old 09-06-2013, 08:14 PM   #13
dmxtothemax's Avatar
Rewards Points: 5,512
They instal them upside down so,
that the electric doesn't run out of the hole
and onto the floor !
Easy !
dmxtothemax is offline   Reply With Quote
Old 09-06-2013, 10:18 PM   #14
Rewards Points: 1,192
Some guys still buy into to old "What If" tale of a butter knife falling behind a desk and landing across a loose plugged in receptacle.
bobelectric is offline   Reply With Quote
Old 09-07-2013, 12:05 PM   #15
Rewards Points: 258
It can happen
well it was plugged into an extension cord not the wall.
redman88 is offline   Reply With Quote
Electrical loading question jimcorey Electrical 2 12-08-2012 07:27 AM
Electrical diagramming questions Texas Couple Electrical 21 12-05-2012 12:26 AM
breaker panel positioning regulations orobono Electrical 1 10-27-2012 03:25 PM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
