Old 01-05-2009, 07:42 PM   #1
UPS powering remote devices using house wiring
I have what's probably a weird, and "why would you do it that way?" question for this group of brainiacs. Bear with me...there's a method to my madness...
A recent power outage showed me that, while my laptop lives for several hours on its battery, the internet connection leading out of my house is not on a battery (only the phone part of it is...frustrating!). So, I'd like to put a UPS (un-interruptible power supply) on my wireless router and internet connection.
The challenge is that the two devices are about 50 feet apart. The wireless router lives in a media panel in the middle of the house. The internet connection that I need to power is plugged-in to an outlet in the garage. I'd like to only have to buy one UPS, because it's spendy to buy two for the two separate locations.
So, the question: can I run 14/2 NMB through the walls & attic from the garage to the media panel, and power that run using the UPS? From strictly an electricians standpoint, I'd likely have an "inlet" (opposite of an outlet) in the garage, next to the UPS there. I'd run a cord from the UPS to the inlet, which would then power anything in the media box (a few watts, at best). Does code have anything to say about this? Would I need a circuit breaker on this thing? I hope not.
Thanks.
MusicMan_234 is offline   Reply With Quote
Old 01-05-2009, 08:09 PM   #2
My License Ain't 4 Sale..
Thanks.
As long as your inlet was terminated in an outlet box, and all wiring was run to code, and your receptacle was attached and grounded properly, I don't see why you couldn't do it. You might go the extra step and label the receptacle and inlet. Overcurrent protection should be provided by the UPS as a fuse or circuit breaker built in.
Old 01-05-2009, 08:24 PM   #3
DIY'er
jamiedolan's Avatar
Thanks.
Why can't the Internet connection device (cable / DSL modem?) be in the same location?
It is much easier to extend a phone or coaxial cable than to extend a UPS.
Jamie
Jamie Dolan - Neenah, WI
Need Help Uploading Photos?
jamiedolan is offline   Reply With Quote
Old 01-05-2009, 09:51 PM   #4
Jamie
Yeah, I would fish coax or phone to the location, much cheaper than 14/2.
rgsgww is offline   Reply With Quote
Old 01-05-2009, 10:29 PM   #5
I would either fish a new coax cable to that location...which must be feasible or else you wouldnt be talking about fishing a 14/2...or I would invest in a second UPS....which for what you need to accomplish would be about $30.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-05-2009, 11:41 PM   #6
I certainly won't argue about the relative ease of extending coax or something. I agree with y'all on that point. BUT, it's not so simple...
I can't extend the internet connection because (without getting into utility names & such, 'cause I don't remember if that's allowed here or not) the internet connection is fiber to the curb, and an OTE module (optical to electrical) on the side of my house; non-movable. That modules plugs in to a 120V outlet. Since I want to have it run when power is off, I want to put a UPS on it.
Now, the media panel in the middle of the house is the right place for the router, all the internet connections, video, etc. It's also not movable, as all the wiring throughout the house runs to that one central location (If I wanted to move it, I'd be moving the router to the garage, and pulling six new Cat5 wires).
So, since I have to provide backup power to both areas, and don't want to move either, I either get two UPS's, or I run power from one UPS to the other area. I'm thinking it's easier to pull one 14/2 than six Cat5.
Thanks especially to InPhase277. One followup question: for the grounding side of things, do you recommend tying the inlet to the main electrical panel's ground bus, or can I allow the UPS ground path to provide the grounding solution (which is how it is with a "normal" UPS installation)?
Old 01-05-2009, 11:43 PM   #7
Is the garage attached to the house? If so, no problem running an isolated 120 volt circuit powered from a male receptacle (inlet). For example if you might power several devices from your UPS.
For an outbuilding such as a detached garage, only one power feed from the main panel in the (main) house to each outbuilding is permitted. But switch loops and lighting subcircuits back to the main house are permitted. This suggests that you could have the UPS out there feeding an isolated circuit serving both garage and house.
The cord and plug for the UPS normally provides adequate grounding, as does the normal daisy chaining of receptacles in an ordinary branch circuit. Still, some installations of electronics experience electrical noise that isn't alleviated unless a separate ground wire is strung from one piece of equipment to another, screwed to the chassis of each piece and with the far end connected to a known ground.
Old 01-06-2009, 08:11 AM   #8
Then in this situation, if the garage is not detached, an inlet would work, and be the most practical.
Old 01-06-2009, 11:04 PM   #9
Garage is attached.
Another follow-up question...sorta. Today I was searching around the internet, and found a "code compliant" Minilock inlet. http://www.hometech.com/hts/item.html?item=LE-80714WML2
What's the story on this thing? Is it required in my situation?
Old 01-06-2009, 11:30 PM   #10
Garage is attached.
Not required. A standard 5-15 configuration would work.
Old 01-07-2009, 12:55 AM   #11
Cable, boxes, connectors - plus labor and effort.
To save buying a $50-$100 second UPS?
Are you sure the economics here make sence?
I like to use UPS's and have multiple units in my house...
Powering computers, network devices, TV's, etc.
Old 01-07-2009, 09:57 AM   #12
zpm
yeah, right
Most inexpensive UPS's only have female sockets in the body of the unit. A short cord would be needed to connect the UPS to the inlet. Would this cord be considered an "extension cord" (therefore in permanant use and a violation), or is the cord considered "something else"?
zpm is offline   Reply With Quote
Old 01-07-2009, 01:01 PM   #13
Send a message via AIM to theatretch85
Ah, thats a good point! I would be curious as to the response on that. Though I do know I have seen some of the older APC UPS's that have a short cord hanging out the back intended for like an ac adaptor to be plugged in. Though it is rather short, but if you planned it just right you could put a small shelf for the UPS to sit on right in front of/just next to the inlet and might be able to use the short cord off the back.
theatretch85 is offline   Reply With Quote
Old 01-07-2009, 01:14 PM   #14
DIYer
If the thing it hooks up to is portable, and it's not taking the place of regular wiring, it's not really permanent, IMHO.
Think about power strips under a desk for plugging a computer into. If that's a violation then everyone in the world is violating it. It's only semi-permanent and it's got built in overcurrent protection, like his UPS.
On a pragmatic level, I can't imagine any inspector having a problem with a properly wired inlet system with a UPS plugged into it. At work we'd use twist-lock plugs to plug semi-permanent wiring that was attached to computer rack frames in all the time, for comparison.
Gigs is offline   Reply With Quote
Old 01-07-2009, 03:40 PM   #15
You've got that inlet right there, I don't see how you would violate code.
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
EXcessive moisture in house geema HVAC 5 09-10-2008 12:18 PM
Wiring stove outlet in old house electric-pete Electrical 23 07-06-2008 04:02 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 09:50 AM
