Upping Generator Voltage?? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 03:17 PM   #16
Apologies for the typo...it is a yanmar L70. This generator was aquirevia the US Department of Defense. Up to this point it been awesome for only the 70hrs it has. Just trying to get it to 230 to run some light duty industrial equipment, dont really care about the 120. Buck boosting is what im thinking, just never installed them; hence i guess my question is really an install question as to how to go about doing it?. Illget a pic of the name plate.
fury902 is offline   Reply With Quote
Old 09-22-2012, 03:37 PM   #17
FYI the generator is a standard MEP-016D model.
Old 09-22-2012, 03:43 PM   #18
Semi-Pro Electro-Geek
Rewards Points: 2,856
You really shouldn't need to use transformers. If you don't care about the 120V output, find the regulator and crank it up a bit. Even if the voltage is still low it should be fine. Measure the motor current while in use and compare it to the nameplate rating. If it's not much higher, then the motor is unlikely to overheat.
mpoulton is offline   Reply With Quote
Old 09-22-2012, 08:14 PM   #19
Missouri Bound's Avatar
The tool is a Suhner Rotofera.
A Suhner Rotofera what? Type of tool and model number please!
Do you want it your way or the right way?
Old 09-23-2012, 01:26 AM   #20
dmxtothemax's Avatar
Rewards Points: 5,096
You should be able to get 230v out of a 208v genny,
Most gennys have a voltage adjustment,
Maybe even just increase the rev's a bit .
A manual would be real helpful.
dmxtothemax is offline   Reply With Quote
Old 09-23-2012, 02:01 AM   #21
Suhner is the manufacturer, and Rotofera is the model name. That's all there is to it. It's a 1.3HP 3phase flexible shaft rotary tool.
The Following User Says Thank You to mpoulton For This Useful Post:
Missouri Bound (09-23-2012)
Old 09-23-2012, 09:06 AM   #22
Mpoulton is correct...is just a three phase rotary tool.
The geny does have a voltage regulator...heres the link to the manual. My setup is exactly the same only upgraded with the yanmar L70 diesal instead of gasoline.
http://igor.chudov.com/manuals/Milit...115-271-14.pdf
Old 09-23-2012, 09:54 AM   #23
Heres a pic of the name plate for the suhner. as you can see its rated for 240 so 208 just wont cut it. im going to try using the voltage regulator...even if i can get 220 from the geny that would b sufficient.
Old 09-23-2012, 03:30 PM   #24
It probably will do just fine on 208V. It would be good to bump the generator voltage up a bit if you can, but it's probably not necessary. You would have to measure the motor current in operation at 208V to find out if it's a problem or not.
Old 09-23-2012, 07:32 PM   #25
Rewards Points: 1,192
1 KW? watta you gonna do with it?
bobelectric is offline   Reply With Quote
Old 09-23-2012, 08:39 PM   #26
I power carve marble. Some days 8-10hrs straight is nothin when i get in a groove. Thats why i have a hard time believing a 240 rated tool can run that long on 208 without overheating.
Old 09-23-2012, 10:22 PM   #27
I think everyone here believes it will work....except fury902. I suggest he contact the mfg. and settle it that way.
The Following User Says Thank You to Missouri Bound For This Useful Post:
mpoulton (09-23-2012)
Old 09-23-2012, 11:17 PM   #28
" Euro " electrician
frenchelectrican's Avatar
We used have 220Y380 volts system before so therefore if you get about 215 volts line to line you are ok with that due there is some leeway with voltage drop it will be simauir to the NEMA ratings but little tighter.
But do not get this motour overloaded on reduced voltage s.v.p.
Merci,
Marc
Old 09-24-2012, 08:25 AM   #29
Rewards Points: 3,130
There is no Army technical manual specifically for a MEP-016D. Must be fairly new. However, do a Google search for "TM 5-6115-615-12" and "TM 5-6115-615-34". These are the operating and maintenance TMs for the MEP-016B. They are Distribution List A (public release) so you should be able to download them.
Old 09-24-2012, 09:07 AM   #30
I would not run a 240V motor using 208V. Normal tolerance is 5% of rated. This is what power generating facilities use, and adjust to out on the grid. The generator has the facility to run at 240 using the leads described on the nameplate. It's all right there for you and you don't even have to adjust the voltage regulator. If you're worried about swapping out the leads, get someone to help you.
lynxpilot is offline   Reply With Quote
Tags
3 phase , boost transformer , electrical , generator , voltage
upping neutral and ground conductors for multiple circuits crankcase Electrical 2 03-18-2011 01:37 PM
