Upgrading The Wiring In My House. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-21-2010, 03:27 PM   #16
Gotcha.
hawkeye12345 is offline   Reply With Quote
Old 06-21-2010, 10:25 PM   #17
Totally screwed together
I think the one I have is 20"x20"x4". It has a bunch of knockouts around the perimeter of the box.
I detailed this in another thread, but here is how you slowly incorporate a new service panel with new wiring:
1. Place you panel and J-boxes - Make sure you are observing POCO and local permit rules (I had to show that the POCO had placed a sticker saying it was OK to place a service panel where I did) You will need to talk with your POCO planning group and your local BI.
2. Take the biggest breaker in your system that is relatively lightly used (stove OK, Air conditioner not so much) and remove the circuit that is on it. Run that existing circuit over to the new panel and place it in the same amp breaker. Run a new circuit back to the original panel, also with that same size breaker, so you are connected with a breaker on each side that is the same size. You are now powering your new panel from the old panel via this circuit.
3. Cut over existing circuits from old to new at your leisure. I ran my whole house off a 40 amp breaker for months while I did this.
xxPaulCPxx is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Underlay for Laminate Flooring Zee 32 Flooring 9 12-13-2009 01:20 PM
Basement flooring question kelot Flooring 2 10-23-2008 04:06 PM
Question about mills on laminate flooring cpsilo1 Flooring 3 07-25-2005 12:05 PM
