Old 06-20-2009, 12:40 AM   #1
upgrading service and running 100 amp to detached garage
I have a detached garage from my house that is 100 feet away i have no electric out there. I was wanting to know if i could upgrade the service from my house from 100 amp to 200 amp and run 100 amp to the garage with 2 2 4 URD. Only thing is i want to put a seperate kinda meter on the garage to see how much KWH im using. anything would help thanks
Tradesman14 is offline   Reply With Quote
Old 06-20-2009, 05:29 AM   #2
Electrical Contractor
kbsparky's Avatar
You will need to utilize 4 conductor URD when sub-feeding that garage. If you want to sub-meter it, that is fine; you can locate that assembly out in the garage.
Old 06-20-2009, 12:32 PM   #3
ok but i already have a 2 2 4 urd buried from when i wanted to start on this last year but any suggestions on wat kinda sub meter to put in
Old 06-20-2009, 12:53 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
The 2-2-4 may be OK to use depending a few factors.
The main one being what code cycle is your area under?
Old 06-21-2009, 12:05 PM   #5
J. V.'s Avatar
And, if you can use the 3 wire feeder, you will connect the wires exactly like the main panel that feeds it. Including the ground rod.
If you use this 3 wire feeder you cannot have any other metallic paths to the structure. Phone lines, water lines etc.... will be off limits to the detached structure.
Running Service to Barn - 100 amp AndrewF Electrical 16 08-16-2009 09:39 PM
Critique my wiring plan for my garage tigereye Electrical 10 03-24-2009 10:55 PM
Running New 100 Amp Service ckladky Electrical 6 01-18-2009 01:57 PM
Running the Generator in the Garage hogger9 Electrical 19 09-26-2008 08:02 PM
upgrading service for added garage jakeb Electrical 12 03-29-2008 01:18 PM
