Old 06-22-2007, 10:05 AM   #1
I have gas!
Clutchcargo's Avatar
upgrading service cable
I'm starting a siding project soon and need to have the meter box and service cable removed from the house. The service cable is old and should be replaced anyway. I thought now is a good time to upgrade the service cable for 200 amp service. I'm not ready to change out the panel and would like to do this myself. Can I have the service cable changed out without immediately swapping out the panel?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 06-22-2007, 11:04 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Yes, you can do this...as long as the cable from the meter to the panel is reusable. There is very little chance you can terminate 200a sized cable in a 100a panel.
You will need permits and inspections for each step of this project if you are doing it in stages.
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 11:00 PM
Upgrading Service to 200 amps sandyman720 Electrical 6 03-30-2007 06:37 AM
Upgrading service sandyman720 Electrical 1 03-15-2007 05:48 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
