Upgrading Service To 200 Amps - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2007, 01:09 PM   #1
Rewards Points: 152
Upgrading Service to 200 amps
Hello All,
I will be upgrading my service to 200 amps. Which size feeder cable from the top of my house to the meter and from the meter to the panel should I use?
sandyman720 is offline   Reply With Quote
Old 03-27-2007, 02:12 PM   #2
jproffer's Avatar
Rewards Points: 706
Call YOUR POCO, they set the spec's for the service entrance. It varies alot. For instance I know of places that allow the nuetral to be one size smaller...where I live, they don't. They all have their quirks, SEC size, ringless meter can or not...etc, etc.
I would also suggest getting an electrician to do this. I know this is the DIY forum, but changing a S/E isn't really a DIY project.
However you do it, good luck to you.
jproffer is offline   Reply With Quote
Old 03-27-2007, 10:40 PM   #3
typically the rule of thumb for 200 amp service feeders are two 4/O wires for your hot wires and 2/O for your neutral. i agree with jproffer though, if you dont know then you should talk to the power company or just get an electrician to do it, although paying someone to do a service change can cost alot of money.
-gooch
gooch is offline   Reply With Quote
Old 03-27-2007, 11:11 PM   #4
jproffer's Avatar
Rewards Points: 706
So can having your house rebuilt because it burned down. If your lucky, it won't even kill anyone .
Old 03-28-2007, 02:38 AM   #5
Especially if the insurance company says that the cause was faulty wiring done without a permit or inspection and denies the claim for payment on the policy.
oldgoat is offline   Reply With Quote
Old 03-30-2007, 02:42 AM   #6
he can pull a homeowner permit and do the work himself and still have it inspected as long as he is the homeowner. at least that how it works where i live in washington state. again i agree that he should have an electrician do the work, but if he gets the service change inspected he should be all right as long as the inspector takes a good look at it to make sure every thing is done right.
Old 03-30-2007, 06:37 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,866
And the part about insurance companies not paying if no "permits were filed" is a long standing MYTH. It is simply not so.
The only time this is true is if it is found to be intentionally malicious. In that case though the insurance company is the least of your worries.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 11:00 PM
upgrading service cable Clutchcargo Electrical 1 06-22-2007 11:04 AM
Upgrading service sandyman720 Electrical 1 03-15-2007 05:48 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
