Upgrading Panel And Adding Grounding Rod - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 08:35 PM   #16
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Originally Posted by Dierte View Post
Also when done correctly double tapping your meter is perfectly legal.
Double tapping the meter is only legal if the meter allows it and the POCO allows it.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-25-2012, 08:49 PM   #17
rrolleston's Avatar
I did my own service years ago and have helped with some other service installs. It's not an easy job but can be done. Best thing to do is install a new service that will meet all code requirements and POCO requirements next to your old service and get it inspected.
And then use your old panels as sub panels that one cluster of a panel should just be replaced and done right with a new panel. I do like the idea of those meter main combo units. You can get one with feed through lugs and feed a 200 amp sub panel inside.
I just did a service a couple months ago with one and it was easy.
For you all you need is meter main, conduit, weather head, wire, ground wire and rods some other hardware items and it could be easily done for under a thousand.
The Following User Says Thank You to rrolleston For This Useful Post:
Missouri Bound (02-25-2012)
Old 02-25-2012, 09:07 PM   #18
rrolleston's Avatar
here is the panel used I bought mine from the local electric supply but this is about the same price I paid. I did an underground service about 50' from the pole. Charged around 1200 and it was only about 700 in materials and a days worth of work.
http://www.elliottelectric.com/Produ...20070727093909
EDIT: I should add they dug their own trench and installed the two required 6x6 posts for me.
Tags
150amp , grounding rod , service panel
Upgrading to a 200 amp panel hartkem Electrical 0 08-01-2010 04:03 PM
Adding a Sub Panel for Transfer Switch dcopps Electrical 27 08-24-2009 10:36 AM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 04:52 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
