Upgrading Garage Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-08-2009, 02:34 PM   #1
Rewards Points: 180
Upgrading garage wiring?
I have one car attached garage that currently has the following things fed by one 15 amp circuit:
-1 Overhead door opener
-1 incandescent light fixture
-1 GFI outlet
Here is what I would like to install in the garage:
-5 more GFIs (two outside and four inside) in addition to the existing GFI
-Install two 24" fluorescent fixtures to replace the incandescent fixture
-Retain the overhead door opener
It probably sounds pretty straightforward but here's the catch-I need the capability to run two 12 amp loads and one 7 amp load simultaneously, which I was assuming would mean that three of the GFIs would have to be on dedicated circuits. Is that the only way to do it? I have about half of my panel open (200 amp service), so the space is there. I was thinking it would look something like this:
Circuit 1: Overhead door opener + two fluorescent fixtures
Circuit 2: 2 Outdoor GFIs + 1 indoor GFI
Circuit 3: 1 Indoor GFI
Circuit 4: 1 Indoor GFI
Circuit 5: 1 Indoor GFI
Does that seem right? Is there a more streamlined way to do it than taking up five spots in the box and running so much wire all the way across the house?
Badfish740 is offline   Reply With Quote
Old 09-08-2009, 02:47 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Sounds like a subpanel would be the ticket. Maybe 50 or 60 amp to the garage then branch out from there.
There's a nice sticky above that explains how to do it.
wirenut1110 is offline   Reply With Quote
Wiring Main-Breaker Box in Detached Garage wstribl Electrical 15 05-11-2013 05:15 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
Critique my wiring plan for my garage tigereye Electrical 10 03-24-2009 09:55 PM
Upgrading garage wiring white29 Electrical 26 11-03-2007 08:53 PM
