Upgrading Garage Wiring - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-03-2007, 12:15 AM   #16
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by SwiftyMcV View Post
NO!!! #6 CU is good for 65Amps, $6 ALU is good for 55 amps and #8 CU is good for for 50 AMPS
***** MAKE SURE YOU GET R90 LOOMEX... basically rated for 90 Degrees C/ (167oF)
SwiftyMcV;
sorry to slam on ya for a min but i do understand you are from Candana area so this OP is from USA [ OP in Georgia area ] and the ampcapity for NM's are diffrent than what you have up there
but basically yeah we have NM-B that is very simuair to your R90 Loomex but to hook up we have to use either 60C or 75C depending on type of wire size and breaker/ fuse termation there so basically ,..
#6 THHN/THWN is good up to 65 amps but here a tricky part when you get to the Loomex [ NM ] the rating drop down to 55 amp [ both at copper wires ]
#6 Alum SER [ 4 wire type ] useally are rated at 50 amp max.
#8 THHN/THWN is good for 50 amp but in Loomax verison it drop dpwn to 40 amp here [ i wont even bother the alum rating on this size but it will be 30 amp BTW ]
hope it will clear up some facts here
Merci , Marc
Old 11-03-2007, 12:18 AM   #17
4th Year Apprentice
yikes then it sucks to be in America lol
SwiftyMcV is offline   Reply With Quote
Old 11-03-2007, 12:22 AM   #18
LOL but you should see how we done in European area i am oringally from France so i know the wire is more weirder than both USA / Canada verison
but dont get into their [ France ] colour codes they have 3 or 4 diffrent type of colour codes it will really make you look like this >>
i been there see there and done that so i know what it will look like
Merci , Marc
Old 11-03-2007, 07:41 AM   #19
Electrician philosopher
Dang, I had my codebook open and everything! In the US romex (the OP specifically referenced Romex in the questios I replied to) must be in the 60 deg column.
Andy in ATL is offline   Reply With Quote
Old 11-03-2007, 08:00 AM   #20
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Swifty, like French says, I assume you are in Canada. Even though this is a non-location specific web site PLEASE be careful in giving advice like this. It will definitely confuse a DIYer from the states. The OP has his location in his profile and it is the US.
Why don't you fill out your profile with your location.
Old 11-03-2007, 12:23 PM   #21
4th Year Apprentice
sorry np, who knew that living in Canada that alot of industries would be soo much easier lol.
One thing USA has going against it is all the different States having different rulings for code. Yes out provinces are ALITTLE different, but they are pretty much 99% identical in our coding in Electrical and other trades
Old 11-03-2007, 01:20 PM   #22
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
One thing USA has going against it is all the different States having different rulings for code. Yes out provinces are A LITTLE different, but they are pretty much 99% identical in our coding in Electrical and other trades
Ooops...you made another incorrect assumption. All states and cities adopt the National Electrical Code and make only a few modifications or exemptions. Such as they may not require afci for bedrooms, or 4 wire feeds to outbuildings. For the most part we wire identically in all states and cities. There are some hardware differences from area to area but we all follow the NEC.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 11-03-2007, 01:28 PM   #23
4th Year Apprentice
sorry i ment hardware differences aswell... in that case we seem to have better "designed" hardware that has winder variances / ratings. One thing you guys would love is Teck Cable... cheap, flexible, rated for direct burial, rated for all weather use, hell it can even be submerged in water(aslong as the connector isnt). Basically landscaping a yard is made damn simple... no more PVC or conduit needed
Old 11-03-2007, 02:41 PM   #24
Around here we've got UF cable which is like romex but is approved for direct burial. So conduit isn't required for 110V landscape lighting south of the border either.
NateHanson is offline   Reply With Quote
Old 11-03-2007, 05:29 PM   #25
4th Year Apprentice
Trust me Teck Cable is superior in every way lol. Not only can it be buried but it can go under driveways/paths or even right in the center of the concrete as it drys. AND it can be run above ground(as in not on your grass ahem lawn mower lol) or on the siding of your house.
Pretty much you never have to transition for any cable type to another when using Teck Cable.
eg) I had to wire a guys hot tub, 120 ft run, run from panel, out through siding of the house, run down the side buried 18 inches deep, then comes up @ the deck and is strapped along the perimiter of the deck just under the lip of it, and all the way up to the disconnect.
Advantages:
simple one run of cable
no transitioning of feeder path/type
no JB's
flexible since its a cable
as resistant to damn as PVC
installs quickly and easily
Disadvantage:
um.... its rarely used in the US
Old 11-03-2007, 06:11 PM   #26
Hey, I'm not trying to get in a pissing contest about your cable. Just responding to the last post where you seemed to be implying that without "Tech Cable" everyone else had to use PVC conduit for underground wiring.
Also, I'm just an amateur, so I'm not sure, but I thought UF could be imbedded in concrete too. Not sure why you'd do this, but my understanding was that it's allowed.
Old 11-03-2007, 09:53 PM   #27
We have a form of tech cable, it just hasn't really caught on.
It is an MC cable rated for direct burial and is approved for use as a spa or pool feeder as well, with NO conduit needed.
Maybe someone know the exact cable designation? I sure don't.
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 12:09 PM
wiring 220 in garage maberry72 Electrical 1 03-12-2006 12:45 PM
Circuit Wiring for Garage Fluorescents realeyz Electrical 6 12-26-2005 04:27 AM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
