Upgrading An Electrical Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 06:25 PM   #1
Upgrading an electrical panel
Just bought a resale home with the electrical panel below that was put in back in 1988. It seems they've used up all the breakers in there, and there is no room for expansion. Am I just better installing a sub-panel instead?
For the experts on here, what is the best replacement for this panel in terms of expansion and with all todays electronics in mind?
[IMG][/IMG]
syndicate1 is offline   Reply With Quote
Old 06-22-2010, 09:26 PM   #2
dSilanskas's Avatar
Just upgrade the panel to a 42 circuit panel. I suggest a Square D QO panel IMO it's the best panel around
dSilanskas is offline   Reply With Quote
Old 06-22-2010, 10:03 PM   #3
Do you have 100a service or 200a ?
Is there some specific reason you want to replace it ?
Planned new electric loads ?
Old 07-05-2010, 09:16 PM   #4
Not really..just thinking there is no room left by the look of it
Old 07-05-2010, 09:22 PM   #5
joed's Avatar
Rewards Points: 11,556
I don't see a main breaker. This looks like it is already a sub panel. What does the main panel look like? If you don't need any more breakers then I would just leave it.
Old 07-05-2010, 09:39 PM   #6
There is another panel in the garage with just one handle to shut off the whole power
Old 07-05-2010, 11:35 PM   #7
joed's Avatar
That is your main disconnect and determines the size of your service. It makes it easy to change the panel IF you want to upgrade. But, unless you need some more circuits now being full is not a reason to upgrade.
A picture from a little further back would be useful. It looks like some of those cables are not fastened in place properly. The panel itself looks fine but the cable could be a real mess.
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Commander Electrical Panel G6716 Electrical 1 05-09-2010 10:02 AM
Passing wire to another panel theatretch85 Electrical 5 09-21-2009 12:09 AM
Electrical panel size WynCntry Electrical 8 05-10-2009 02:39 AM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
