Upgrading Electric Service - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2009, 02:17 PM   #1
upgrading electric service
Who do you call first? An electrician or the electric company to find out if the line going to the house will support a 400 amp service.
HitmanZR is offline   Reply With Quote
Old 06-28-2009, 03:55 PM   #2
Electrical Contractor
kbsparky's Avatar
Are you increasing your connected load by double? In most cases, the POCO will not change anything ahead of the meter unless you are substantially changing the total connected load.
Call the electrician first. If you have doubts of what he says, then call the poco for confirmation.
-KB
Old 06-28-2009, 03:57 PM   #3
I called the POCO 1st to find out if I could even get 400a service
They said I could with new wires
Old 06-28-2009, 04:58 PM   #4
In our case, you just call us.
We will call the power company.
Your existing "line" will need to be upgraded to support the 400A service.
Overhead, no big deal. Underground, bigger deal.
220/221 is offline   Reply With Quote
Old 06-28-2009, 05:41 PM   #5
Rewards Points: 502
This was not the case for my house.
Back when the original service was installed underground in the 70s, 4/0 was installed
I just finished an upgrade to 400 amp service, and the POCO installed 4/0 in new conduit I ran....as the old was not in conduit and we are re-locating the transformer further from the house.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 06-28-2009, 07:45 PM   #6
We currently a have 200a panel. The house was built in 79 and im sure it is the same service that was originally installed. It is all underground and from what I can tell mainly under concrete.
Old 06-28-2009, 08:04 PM   #7
Do you have a transformer on the property?
Or is it all from the pole?
Are all utilities in the area underground?
If the cost of as transformer upgrade (on your property) is your responsibility then the price will go up
I'd call the POCO 1st - that information will be free
Of course if you have an electrician like 220/221 who will find that information out for you - also for free - then you could do that
Old 06-28-2009, 11:09 PM   #8
I should have said that, based on the hundreds I have seen, the line will have to be changed.
Need opinions on the cost/necessity of upgrading service. Simplemines Electrical 3 10-19-2008 09:41 AM
upgrading exsisting electric heat brokenbobby HVAC 4 09-15-2008 08:36 AM
upgrading service for added garage jakeb Electrical 12 03-29-2008 12:18 PM
upgrading service cable Clutchcargo Electrical 1 06-22-2007 10:04 AM
Upgrading Service to 200 amps sandyman720 Electrical 6 03-30-2007 05:37 AM
