Upgrade Or Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2009, 10:56 AM   #1
upgrade or sub panel
I am buying a home with a 100amp entrance. I am putting in an electric hot water heater, but already have an electric range and dryer. Do I need a subpanel for the water heater or do I have to change the whole entrance??
hvyhln is offline   Reply With Quote
Old 03-13-2009, 11:40 AM   #2
you need to do a load calc....how may square feet, other appliances, ...if i had to guess, yes, you will need a bigger service
NolaTigaBait is offline   Reply With Quote
Old 03-13-2009, 11:46 AM   #3
Res Ipsa Loquitur
Just to clarify- in a typical residence your MAIN breaker is what determines the amount of amperage into your house. You are saying subpanel but if it comes off of the main entrance, you haven't gained any amperage. A subpanel just makes more divisions (and more control) from the main entrance.
An upgrade in your MAIN service may be necessary (to 200a possibly) but as already mentioned- a load calc needs to be done to determine if it is really necessary.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 03-13-2009, 12:31 PM   #4
Rewards Points: 78
How many spare breaker slots do you have. If you have 2 you can install a 2 pole 30 amp breaker and run #10/3 cable for the WH. If you have the spare slots don't concern yourself with a load calculation. Your panel is designed to hold as many breakers that it will accept.
If you do not have any spare breakers you can use tandem breakers to free up some space. You must be sure your panel will accept tandems and how many! 100 amp services are not always to small. In fact it may be just right for your house.
J. V. is online now   Reply With Quote
Can I upgrade my main panel? MarkinTexas Electrical 8 01-22-2009 11:15 AM
Upgrade Service Panel - Do I need a new meter? El Kati Electrical 6 08-11-2008 08:35 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Any electricians out there? Panel upgrade! roncon Electrical 1 06-19-2005 01:38 PM
