Upgrade Or Rewire - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 06:52 AM   #1
Question
Upgrade or rewire
We don't plan on DIY for this since we know NOTHING about electrical, but thought you guys might be able to give your opinion.
This is the problem in a nutshell...
Old house.
Lights always have flickered.
Can't seem to handle everything we have running (ie window air conditioners) as outlets seem to flicker on and off when some things (like dryer or washer are cycling), and upper floor blew a fuse last week when the kids plugged in too many things.
Ideally we probably need to rewire the entire house, but that isn't in the budget (I have heard it can cost $10000 - $30,000 - is the correct??)
Could it be that it needs to be upgraded too 200 amp? Whats involved with that? Do you need to rewire to have that done?
Any advice you can give so that I make sure I make an informed decision when the electricians come here to give me an estimate would be greatly appreciated.
Thanks!
Lexiesmom is offline   Reply With Quote
Old 06-29-2010, 09:23 AM   #2
Rewards Points: 320
There are two different issues here. An upgrade to 200 amps is a service upgrade and you may or may not need it depending on what you have for service now, the condition of your panel, and what your electrical demand is. As far as the circuits going throughout the house that depends on the condition of the wiring as to what needs to be replaced. A whole house rewiring might be in order if you have very old wiring such as knob and tube or very old cable. It is impossible for anyone to give you advise on cost without seeing the job. A total rewire can be easy or difficult depending on your type of house and framing. Your best bet is to call several electricians and get estimates.
teamo is offline   Reply With Quote
Old 06-29-2010, 09:28 AM   #3
Flickering could be a loose neutral & needs to be fixed
Or do the lights flicker when the AC or other heavy load kicks in ?
That might be just being on the same circuit
Where are you located ?
What size service do you have ? 60a. 100a ?
Is it actually fuses...or do you have breakers ?
What do you have for electric loads ?
Dryer, stove, hot water, heat ....or ?
Old 06-29-2010, 10:02 AM   #4
Or do the lights flicker when the AC or other heavy load kicks in ? It seams to be when something else is turned on.
Where are you located ? Ontario, Canada
What size service do you have ? 60a. 100a ? I'm not sure.
Is it actually fuses...or do you have breakers ? Breakers
stove, fridge, computer, tv's, fans, window air conditioners (4 in total, but normally only 2 are running at once)
Thanks for your help!
Old 06-30-2010, 08:21 AM   #5
the Musigician
DangerMouse's Avatar
It still wouldn't hurt to cut the power and go through the panel and tighten anything that may need it.
"Couldn't hoit! woowoowoowoo! Hey Moe!"
DM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 08:17 PM
400 Amp Upgrade / Transfer Switch AndrewF Electrical 50 07-04-2009 07:33 PM
Can I upgrade my main panel? MarkinTexas Electrical 8 01-22-2009 10:15 AM
Upgrade Meter Box Help BenJoeM Electrical 10 10-24-2008 10:58 AM
