Upgrade LoadCenter Above Ground Level Rule - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 10:53 PM   #1
Upgrade LoadCenter above ground level rule
Planning for my LC upgrade, checking and double-checking, and I appreciate your expert help ahead of time.
AGL: I'm replacing a 30+ yr-old external-mounted LC box with a new CH -R box. Existing box is shorter (~21" high) and presently sits about 57.5" AGL (above gnd level), whereas the new box is longer (~37" H) and, based on how I want to place it per my present design model, would sit about 47.5" AGL.
My motivation for this particular box placement is that I need to place the new LC such that I minimize the # of splices, while maximizing the # of direct connects to the CBs. I want to avoid splices like the plague, if I can (which I think is reasonable approach).
I don't remember seeing any local Phoenix code or our adopted NEC-2008 requirements for AGL or minimum clearance requirements for an ext load center. Seems to me I've seen LC boxes on newer houses that have a lower AGL than the one I presently have. (I'm trying really hard not to say... the one I currently have).
What say, am I OK? Your expert code-based opinion, please. Thanks again ahead of time.
Johnd85053 is offline   Reply With Quote
Old 01-27-2012, 02:42 AM   #2
Electrical Contractor
kbsparky's Avatar
Only mobile home service disconnect boxes have minimum height requirements: It must be at least 24" above grade to the bottom of the panel.
-KB
Old 01-27-2012, 06:32 AM   #3
Sparky
Rewards Points: 510
as long as all of the breaker handles are under 6'6" above grade, you're golden. height wise.
Techy is offline   Reply With Quote
Old 01-29-2012, 09:39 PM   #4
Perfect, thanks a bunch!
Old 01-29-2012, 09:41 PM   #5
Licensed electrician
Rewards Points: 1,610
Actually it is 6' -7" to the center of the handle. The inch matters.
Old 01-29-2012, 09:43 PM   #6
OK, thanks Jim for that clarification! I'll note that on my Plan.
Old 01-30-2012, 02:15 AM   #7
Sparky
Rewards Points: 510
you're right, 6'6" is the Local POCO's max meter height.
Upgrade Loadcenter fblankinship Electrical 5 10-27-2010 12:15 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Service Upgrade - Ground Bonding Question AndrewF Electrical 28 06-15-2009 01:25 PM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 08:52 AM
